Question about Air Tools & Compressors
Need a new spray gun and attachments .where can I get them
  • 1,830 Answers
Try Home Depot.
Posted on May 11, 2017
How do you take this hvlp gun apart for proper cleaning of the spray gun?
I've found over the years the least amount of times you can tear a spray gun completely apart the better. Usually a real good 'flushing' with lacquer thinner will suffice. I will take the air cap off and let it soak in thinner to dislodge any build up but other than that, I simply run thinner thru till it runs clear out the tip.
I also 'back flush' which involves having thinner in the cup and the air supply hose attached. the air pressure should be adjusted quite a bit lower than what you use for spraying paint.
Then you place a clean shop towel or rag over the air cap of the gun and pull the trigger. This forces air back into the paint cup 'back flushing' the gun. Then take the rag away from the cap and pull the trigger again to run thinner thru the gun the normal way.
IF you still want to tear the gun apart for cleaning you can hopefully get some idea with this video link;
Quick Easy Way to Clean HVLP Spray Gun
Hope this helps.
May 25, 2015 | HVLP Air Tools & Compressors
Doesn't stop spraying after trigger is released
Dear Peggy,
You can have a problem with the valve at the gun which is sticking open. This valve can be OK without pressure, but with pressure it can stick open. It is very easy to make sure, by attaching a good gun or a new gun. In simple words...replace the gun.
Feb 27, 2014 | Karcher K3.68MR Electric Pressure Washer
Can I use my Kirby Spray Gun for coating a paint over the wooden items like windows, wooden shelters etc.?
It can be used, but be sure to use a water based, non-flammable paint or stain. Blow the dust out of the hose before attaching the spray gun.
No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See for detailed tip combinations.
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
Bad air flow. it doesnet seem to be spraying out of the fan correctly. In fact, i don't even get a noticable fan spray. it just sprays a round pattern no matter what i do.
Check none of the air holes int he cap are blocked. Also there is a small wheel adjuster on the left side of the gun, or perhaps even on the top which will adjust fan spray shape.
Of course you need about 30-40 PSI pressure at the gun end for it to spray properly, as well as a compressor with about 12-15cfm air flow rating to use a HVLP gun efficiently.
Apr 16, 2010 | Sharpe Manufacturing FX300 HVLP Spray Gun...
Titan spray gun issue
the fitting on the gun is bad or the wrong one. get a new one with the right threads for the gun end and the corrisponding fitting for the hose end. gun may be npt thread and hose might be jic thread.
chances are home depo has the correct fitting.
Oct 28, 2009 | Air Tools & Compressors
How do you diagnose a Campbell Hausfeld Airless. It will not prime nor spray?
Try to fill it with water and spray. YOu may have paint buildup in the system, and will have to disassemble it to clean it
Oct 25, 2009 | Campbell Hausfeld Airless Spray Guns &...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
