Question about Refrigerators
RF4287HARS/AXA water dispenser turns on by itself and keeps dispensing get water
  • 6 Answers
SOURCE: water dispenser dripping
HVACRH20, are you any good with GE water dispensers dripping? Let me know, I have a lot of info to provide and maybe you can help answer my problem?
Posted on Apr 02, 2008
milten1
  • 1304 Answers
SOURCE: kitchenaid no water, but ice
first thing i would check here is my water resivoir, on these models it has a tendency to freeze,, hit the tank and upper line with a hair dryer for several minutes then give the water a try....
barring that it may be time to change your water filter even if the sensor has not picked it up yet
Posted on Oct 26, 2009
SOURCE: Water dispenser keeps freezing GE Refrigerator
If this is a newer model GE side by side refrigerator, this is not uncommon. what you can do to check to see what is going wrong, remove the toe plate at the bottom front of the unit. Under the freezer door, you will see a white plastic water line, with an inline connector about 4-5" from where the line comes out the bottom of the door. this is normally a blue push-in type connector. On this connector, you will see two white sleeves on either side, push in on this sleeve while pulling the corresponding water line section out of the connector, if you squeeze the sleeve enough, the water line will slip right out. Place a towel on the floor, make sure both ends are on top of towel. Now, breifly actuate your water dispenser trigger, see if water comes out the exposed water line. If water comes out, your entire water dispenser system is OK, but, the water line in the freezer door is frozen, in which case the only way to melt it, is to turn the unit off, open the freezer door, and blow a fan for a few hours, to melt the ice INSIDE the door. You could also buy a new door, but that is very costly.
If no water comes out the exposed water line, then either your water filter is clogged, or you have a bad water valve solenoid
Posted on Feb 15, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: water dispenser will not dispense water ice
eqwe
qe
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed. I suggest you call a service company.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Posted on Dec 23, 2010
Testimonial: "thanks for the suggestions"
  • 403 Answers
SOURCE: The water dispenser keeps running
you have a bad water inlet valve. replace the valve and your problem will be solved
Posted on Jul 16, 2011
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Water is coming out of door dispenser with little pressure. replaced filters didn't help
Look for a pinched water line. If there is a shut off valve fin the water line, make sure it is fully open. I can't imagine there is blockage some where in the water supply line.
Apr 18, 2015 | Samsung RF4287HARS French Door...
Water dispensing slow
Check out the water filter it may need replacing, I have seen the odd time the pipe is almost frozen. Had to defrost it.
Mar 13, 2015 | Samsung Refrigerators
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
I have a Frigidaire GHSC39EEPW1 side by side with ice and water dispenser in the door.It keeps dispensing water by itself.It even does it when locked.What could be the cause of it
Hi Steve Garner - There are a couple of factors that can cause a side by side dispenser to dispense water by itself. The refrigerator could possibly have a faulty valve, dispenser control board and/or failed water valve diode. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Mar 03, 2013 | Frigidaire FRS26R4A Side by Side...
Samsung rf4287hars dispenser not dispensing ice
SAMSUNG RF4282/HARS has a total backwards-double negative on the menu screen ( at least to me ) tho granted, the ice maker is perhaps, lets say, one of the slower cube makers I have ever seen... it has a setting that is .... "Ice Making OFF".... with the option ON/OFF.... make sure that setting is set to OFF if u want ice, or non Orange on the ON screen, or no ice will be made... It could have been worded much better... ie: "Turn Ice Making Off" with option yes or no... but no... My mind says...Make Ice, have options yes or no = just that....if I select YES ... ice making should be on.... not with Samsung... Kinda should go with the other setup settings that Samsung has..... simple yes/no
Words are.... ( selection )
"Ice Making OFF" setting should be set to OFF... just to do that... you are turning the shut down mode OFF and u will be making ice ( you are turning the shut down ice making function OFF in common terms)
As expensive as this machine is.... It should be easier and programing should restore after a power flux.... anyone wanting a lot of ice... forget this machine... we continue to purchase bagged ice and keep it in the freezer in the garage, it can\'t keep up on a daily basis.... I continually have to re-enter my WIFI passcode at every power outage... ( sometimes a lot in summer with storms )
My wife wanted it.... steel look.... she now finds she hates keeping it clean... NEVER AGAIN.... Samsung has some great products, but we have to suck up on this one... never again
Feb 27, 2013 | Samsung RF4287HARS French Door...
Ice dispenser problem Samsung rf4287hars
Check that you ice maker is on, do you have ice in the bucket?
Check you ice drain is not plugged. Do you hear some humming noise when you push the ice dispenser? This could be a complex problem.
Feb 27, 2013 | Samsung Refrigerators
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
