Di5510 code to enter porgram mode - Office Equipment & Supplies
Error code sc36-03 ?
On what model of machine is the code showing?
Feb 15, 2015 | Konica Minolta Office Equipment & Supplies
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". close out to original screen and power off the machine. wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Feb 15, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
How i change the developper of konica di5510 plus the code of it
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Feb 04, 2015 | Konica Minolta Minolta Dialta Di5510 Laser...
Operation mode di5510
adimin mode or service mode?????
May 06, 2014 | Konica Minolta DiALTA Di200 Copier
Konica minolta bizhub Di5510 driver for windos 8
You can try konicaminolta web site drivers are free. But Di5510 I believe best you can do is XP or windows 95. But give the web site a try.
Sep 26, 2013 | Minolta bizhub 200 All-In-One Printer
Fix-it utilities 8
restart teh computer. press F8 when you see the harizontal bar scrolling at the buttom.
go to save mode.
uninstall the porgram from contaol panel>> add and remove porgram.
restart the computer.
Nov 06, 2008 | Microsoft Windows Vista Ultimate Edition
Bizhub Di5510
SC49-01, SC49-02, or SC49-03 codes.
[Solution]
PROBABLE CAUSES:
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di5510 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch turned off, the Service Code will be generated the next time the printer is restarted.
Jan 03, 2008 | Office Equipment & Supplies
24 people viewed this question
k24674
jasbo
jasbo
