Was all ok till a couple of weeks ago, AM has interference but sometimes gets sinal for a few minutes but then goes and on FM I can only get BBC and the odd local station
SOURCE: Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
SOURCE: FM Radio doesn't work
it may be that the fm detector has failed or possibly a tank(tunning coil)
SOURCE: Radio stations fuzzy and not coming in anymore - Sony CDX-GT310
i have the same problem, it was a factory fit and the garage checked it and all the connections were ok, it appears to be a fault with the receiver.the radio is just 3 years old.
SOURCE: AM reception/AM power problems
A portable Loopstick tuning antenna is probably the BEST option. Also, the quality of the portable radio you are using is vital since the internal ferrite loop antenna is the single most important factor when attempting to use electromagnetic coupling for better radio reception on the AM (Medium Wave) band. That being said, the obstacle of a metal building's 'signal-shielding' may make it impossible to receive inside some areas of the structure. {Mark • KC9TSR}
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
• A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
• If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
• Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
