Question about Hampton Bay Dryers
My Hampton Bay fan /light stopped working. I took my wiggle stick and tested the wires for power. All the wires tested hot. Both wires that feed the light are hot.
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 1810 Answers
SOURCE: Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Posted on Jul 29, 2009
  • 302 Answers
SOURCE: I have a Hampton Bay fan with lights. The lights
YOU NEED TO USE ROUGH USAGE BULBS DUE TO THE VIBRATION FROM THE FAN.
Posted on Aug 13, 2009
How to wire ceiling fans
Some home depot guy bored?
Aug 17, 2014 | Hampton Bay Dryers
Hampton bay springview
Make sure the blue wire from the top of the fan is connected to the hot wire in the ceiling.
Aug 06, 2013 | Dryers
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
I need a wiring diagram of the Hampton Bay fan with light. The fan is black and white and the light has a blue wire. I believe the blue should be tied to the black, am I correct. Thanks
Twist the bare conductors together tightly, matching the black and blue ceiling fan wires to the black power wire, and the white ceiling fan wire to the white power wire, don't forget the green ground !!
Sep 10, 2010 | Hampton Bay 24002 Ceiling Fan
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
I have a hampton bay UC7087T that stopped working - both the fan and light. When you flip the switch the light flickers on then goes off and never comes on. Anyone seen this? Thanks.
You likely have a bad connection to the power input of the fan. Could be a loose wire nut someplace in the feed to the fan. Probably right at the fan and vibration has worked it loose. Check the connections in the box the fan is mounted to.
You should probably turn off the circuit breaker for safety while doing this. Often the wires will spring out of the loose connector and you have a handfull of hot wires!
Oct 24, 2009 | Dryers
4 wires only one hot, two outlets and one switch and the ceiling light...to install ceiling fan can't get wiring combo correct???
the one set is probably a feed for the outlets ...the other is a control set ...wire it to the control set then tie in the outlet pair...the switch only controls the feed end
Sep 19, 2009 | Hampton Bay 24002 Ceiling Fan
there cheep 2-5.00
Jul 29, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Jun 08, 2008 | Dryers
Hampton Bay ceiling
When I've installed these fans in the past, the blue wire was for power to the light kit. If you don't have a light kit, just tuck it out of the way.
Aug 12, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Dryers Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
