  • 1,830 Answers
How old is this washer and what make and model is it?
Posted on May 11, 2017
Problem with my bosch wash mch
Check timer to insure the cycle is completing sometimes the vacuum sensing line gets plugged and cycle may not complete
Mar 04, 2015 | Bosch Washing Machines
Bosch shu5316uc filling fault
Test the water inlet electro valves.
May 26, 2017 | Bosch SHU5316UC Dishwasher
Need to retune free view as has never been done since buying
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
Jan 14, 2011 | LG 42PX5D 42 in. Plasma HDTV
On ps3, when switched on, says hard drive corrupted, will restore. after a while trying to restore, same thing comes up again.
  • Turn off the PS3 console, if it isn't already.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Connect your controller to the console with the USB cable when prompted to do so.Turn on the controller. You will now have access to the PS3 recovery menu.Select option three which states "Restore File System: Checks for corrupt/missing system files." This option will identify and correct and corrupt files. Your PS3 should now be fixed. If this option doesn't fix your problems, you'll want to do a complete system restore and follow the next step.Turn off the PS3 console by holding down the power button.Press and hold the power button on the console as it powers on, and then powers off again.Press and hold the power button a second time until you hear two consecutive beeps. If your console powers down before you hear the second beep, try holding down the power button again. It should work during the second cycle.Select option 5 which states "Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch." Be aware that performing a complete system restore will cause all data on the hard drive to be lost. This option restores the PS3 back to its original factory condition.
  • Dec 06, 2010 | Sony Playstation 3 (PS3) Console
    1 Answer manuel...first time using washer. pushed regular, large, cold, pause resume. When it finished filling with water it beeps 3x than stops for a couple minutes then beeps 3x etc. It is filled...
    Your problem is with the pause/resume button. This button allows you to add/remove items before the cycle is complete. If you press this button and there is water in the machine it will beep for a period of time (3 mins) and then empty the machine automatically so you can open the door. After opening the door the cycle can be restarted again by pressing the pause/resume button again.
    Nov 07, 2009 | Washing Machines
    We have a La Cimbala M2 barsytem that indicates press cleaning button, where is it?
    The top left button on the 2nd row of smaller buttons. It has a filled cup as an icon. press and hold until screen says 'short wash' or group wash. There is also a full cycle washing that is required some time during the day usually at night or start of a work shift. This requires the opening of the 'de-cafe' or pill drop chute. It's a small black slide about the size of a pack of gum. open it and drop a cleaning pill then close it. the panel buttons will blink and the screen will say press cleaning button. press and hold the wash button (as previously mentioned) till the cycle starts to clean. Release button and allow 8 mins for the cycle to complete. This will keep the 'clean cycle' clear until the next shift or next day when it needs to be done again. These instructions should be in your manual that came with the machine.
    Sep 27, 2009 | Espresso RMI La Cimbali Espresso Machine
    Trying to program a remote, but it doesn't work.  i followed the instructions turned the key from off to on 8 times and left it at on, but the locks did nothing. can you help?
    1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
    RUN. Door locks will cycle to confirm programming mode.
    2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
    to confirm programming.
    3. Within 20 seconds, press any button on second keyless remote. Door locks will
    cycle again to confirm programming.
    4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
    Jul 08, 2009 | 2002 Ford Taurus
    Clean light won't turn off, new wash cycle won't start.
    Press these buttons in succession, within 5 seconds: high temp wash, air dry, high temp wash, air dry. If the sequence is entered properly, all of the control panel LED's will illuminate simultaneously. Once this happens, press the cancel button twice. Now you should run a complete cycle again. If the dishwasher actually has a problem, it will fault again (means the unit isn't heating properly). If not, it's business as usual.
    Apr 25, 2009 | Dishwashers
    Reset keyless entry on 1998 honda civic
    Okay, here goes-
    1. Turn Key to on position.
    2. Push and hold **valet button on the stock radio.
    **Valet button is skinny bar located between am/fm & cd/tape buttons on stock radio.
    Door locks will cycle one time.
    3. Press any button on remote one time within 20 seconds. Door locks will cycle again.
    4. To program up to 4 additional remotes repeat step 3 for each additonal remote.
    5. Turn key off programming is complete.
    Thanks for using Fixya, please rate if this helps :)
    Mar 16, 2009 | 1998 Honda Civic
    Washing Machines Logo
    24 people viewed this question
    Top Washing Machines Experts
