Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
The washer keep stopping with about 12 minutes left in the cycle and displys "HF".
    Problem Solver:
  • 11 Answers
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Posted on Nov 21, 2007
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Flashinf H F
check your fill hoses,,for kinks,,or clogged,,the unit is detecting no water ate one or booth of the fill hoses..clean your screens,,,onthejob
Jan 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My duet washing machine throughs out a FH code
FH is a water inlet related issue, make sure your cold water supply is working correctly, sounds as if its trying to rinse(cold water) and has no water to do it
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HF alarm
1st ck all hoses and screens for blockage be sure you have good water flow to washer next remove top ck flow meter left side 2 small hoses 1 in one out may be able to tap it on the side and temporaily correct problem best bet is to replace it
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Oct 14, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Jun 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
87 people viewed this question
Dan Webster
Dan Webster
Sal De
