Question about Welding Tools
Feed display fails to light up but everything is welding correctly? Not sure where to start.This is on a Miller 70 series feeder S-74D.
SOURCE: miller axcess 40v wire feeder
just checking to see if you got any ideas on this problem
Posted on Oct 27, 2008
713printech
  • 32 Answers
SOURCE: paper jam in auto feeder
Well you should be able to pull out the whole sheet of paper. If the jammed paper has a piece missing, then you did not clear the jam completely and will have to in ther and retrive the torn piece of paper.
The source of the jam can be a worn p/u roller or an obstruction in the paper path.
Posted on Jan 06, 2009
mamicheddy
  • 79 Answers
SOURCE: miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
Posted on May 08, 2009
  • 81 Answers
SOURCE: Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Posted on Apr 21, 2010
  • 81 Answers
SOURCE: Miller S-54D 115V digital wire feeder that does not weld right.
Hi Kevin,
Causes of poor penetration: Travel speed too fast, welding current too low,
poor joint design / and or preparation, electrode diameter too large,
wrong type of electrode, excessively long arc length.
Solutions: Decrease travel speed, increase welding current, increase root
opening or decrease rootface, use smaller electrode, use electrode with deeper
penetration characteristics, reduce arc length.
Posted on Jul 20, 2010
When welding the lcd screen will go blank and come back on with a different program settings
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check the input AC voltage too; while welding. If it go beyond normal; for example, when electrodes of the welding machine are touched together during welding; the making will take a large amount of current from the AC line; causing the voltage to drop momentarily.
This too can an other cause. Check out.
Jun 22, 2015 | Miller S-74DX 70 Series Single Wire Feeder
Miller S-64 wire feeder won't feed wire
Just a thought, have you tried feeding the wire manually to see if there aren't any obstruction through to the handle or nozzle? Hope this helps
Feb 02, 2018 | Welding Tools
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
I have a Miller Shopmaster power source attached to a Miller model 22A wire welder. The problem is when the heat is set above 150 the wire feed pulsates and will not maintain a constant wire feed. Do you...
Check to make sure wire feed brake is not set too tight and that all cables and gun are clean. Also check wire feed wheels are clean and in good shape
Apr 09, 2011 | Miller Welding Tools
Miller mig welder #175 stopped welding, fan comes on and wire does feed, just no weld.
This usually happens when the main Power semiconductors fail. You need to check out the two main places, the Power Supply, make sure ALL voltages are correct, and the main Output semiconductors, check these to make sure they are Not open circuit or short circuit.
http://www.millerwelds.com/service/ownersmanuals.php
Above is your support link.
You need to contact Miller and obtain a service manual, before attempting to service this unit.
Aug 14, 2010 | Miller Welding Tools
Hi Kevin,
Mar 24, 2010 | Miller Welding Tools
Wire won't feed or arc fan runns
Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
Im tryint to conect my wire feeder
ask weld tech at a welding supply store and ask if your components are compatible (since most wire feeders are 24 volts).
Dec 19, 2008 | Welding Tools
60m series
Phone Miller sort it in a jiff.
Sep 23, 2008 | Welding Tools
Miller axcess 40v wire feeder
give me a day or so and i will have the solution for you
Sep 11, 2008 | Welding Tools
Welding Tools Logo
52 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
