Question about The Home Security
I have a farewell safe - SW 200700 & have lost the key, battery also drained so keypad not working. How can it be opened.
  • 347 Answers
I have to ask the obvious question. Can the batteries be changed from the outside? If not, I would call a locksmith to drill out the lock or pick the lock. He can also make you a new key for it once it's open.It won't be cheap, sorry.
Posted on May 11, 2017
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
How can we open a digital safe?
Normally the safe should have come with a key to open it in the event that the keypad fails. Even if there is no key you can call the manufacturer and supply them with the serial number and they should be able to help you. I had a similar problem where the keypad on my safe failed and the manufacturer sent me a new keypad within two days.
Aug 13, 2014 | Home Security
I have a Micromark digital safe which the batteries have died and I cannot find the key to open it manually. Where can I get a replacement key or are there any instructions to open the safe manually...
There are a few things to try: "lock bumping", heating the safe up or depending on the mode, some have a little cover that you remove and hold a PP3 9V battery across two terminals to supplement the internal power to allow it to drive the solenoid.
There are loads of video's on youtube about "lock bumping" but I have to admit that this does not always work and did not work for me when I was in exactly the same predicament.
As my "NuTool" safe did not have a place to fit an external PP3 battery, the way I got into the safe was to heat the safe up. I used a cheap £10 fan heater to blow heat onto the safe keypad (make sure you do not put it on too hot as we do not want to melt the keypad or plastic).
Leave it on for about 4 hours and then try it. Warming batteries temporarily makes them work better but it is only temporary. You would have to immediately replace the batteries as soon as the safe is open.
Feb 06, 2011 | Office Equipment & Supplies
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
Feb 19, 2010 | Sentry Fireproof Safe
I have a gordon digital electronic safe # P45891, lost combination .how to open it?
Take the single screw off of the entry pad and remove the cover plate. Using the key that came with the safe, unlock the safe. Now, look for a little red button on the inner hinge. Push it in and you will note the yellow led on the the front of the safe turns on. Now, enter a 4 digit code of you choice. This is automatically saved and is the new 4 digit code you press to open the safe.
Jun 30, 2009 | Safe International Digital Electronic Safe...
Home Security Logo
Top The Home Security Experts
Lawrence Oravetz
Are you a The Home Security Expert? Answer questions, earn points and help others
