After calibrating I receive a "fymmain" error .Please advise?
No sound from a Tx-sr808
I would advise to start with a reset of the unit. Immediately after the reset go into the level calibration menu of the receiver. In that menu if you are not getting test tones from the receiver then it would either have to go in for service or be replaced. Thanks, FM9
Jun 19, 2016 | Onkyo TX-NR801 Receiver
Error code HC11111
Anna, without knowing what your device might be, we're not going to be much help....
Oct 29, 2015 | Office Equipment & Supplies
I have a York evolution tv treadmill model x8 which starts for about 3 seconds then stops with E7 on the display, I understand this is a safety key error code but the key is in place and if it's...
Definition: Incline motor calibration abnormality: 35~40 seconds after the down command was sent,
the calibration base signal was not received.
Check the calibration motor (mechanical +electrical)
Jul 11, 2011 | York Barbell Home Use Fold-Up Treadmill
Trying to burn a dvd and i get this error please advise Module sfmmcx.cpp Line 2240 A medium error occurred. A Power Calibration Area error has occurred.
Your software and hardware are conflicting. Need exact problem for an exact answer. What type of burner, what type of program or software is trying to burn.
Feb 18, 2011 | Computers & Internet
Why Error: 0xd0620130 in HP Officejet 5610 comes, pl. advise
Power reset.
Without turning off the product, disconnect the USB cable from the rear of the product.
Remove the cartridges from the product.
Wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
Oct 27, 2010 | Office Equipment & Supplies
All service codes for ricoh aficio 1075 are required urgently.
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Aug 11, 2010 | Ricoh Aficio 450 Copier
HOW TO CALIBRATE GARMIN STREET PILOT 2620
I am assuming you want to calibrate the touch screen. Press MENU, click DISPLAY, Press find, press find, follow instructions on screen. You can also hold MENU and FIND at startup and a diagnostic screen will start up, pressing menu repeatedly while on this screen will give you an opportunity to calibrate the screen. If you are looking for a solution on how to do something else, please post additional information and I will do my best to assist.
Jun 06, 2009 | Garmin StreetPilot 2620 GPS Receiver
What is the matter with "calibration error (1042)" in plotter?
HP actually recommends that you contact them directly when you get this type of error message.
I can provide a link for you to access their troubleshooting online, at http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=82218&prodTypeId=18972&prodSeriesId=82218&objectID=bpp02995
where you can click on the contact HP link in calibration errors to receive further assistance.
Here's that link:
Click here for information on contacting HP support at http://h20000.www2.hp.com/bizsupport/TechSupport/CallHP.jsp?locale=en_US&docIndexId=179680&taskId=101&prodTypeId=18972&prodSeriesId=25301.
If that doesn't interest you, you can browse the HP support forums, and you will find other examples of printers like yours with the same or similar errors, and HP experts who guide them through the fix. http://forums13.itrc.hp.com/service/forums/bizsupport/categoryhome.do?prodSeriesId=82218&lang=en&prodTypeId=18972&categoryId=414&cc=us&admit=109447627+1238315749385+28353475
That's my best advice for a quick solution, to go straight to the source. After all, they have the most experience with these things...
If somehow I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 29, 2009 | HP DesignJet 5500PS InkJet Printer
Printer is showing a system error of oxc19ac3ff ink system failure and will not print receive faxes or copy please advise
I had the same problem & found the solution of HP's website. It solved the problem.
HP Website & solution:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00489814&dlc=en&product=1153494
Solution one: Reset the product
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
61 people viewed this question
k24674
jasbo
jasbo
