Question about Mitsubishi Televison & Video
I have a Mitsubishi 65 in tv model WD-65733 it turn on to white screen then green light flashes and it turns off?
    Top Expert:
  • Mitsubishi Master
  • 74,999 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on May 12, 2017
  • 117 Answers
SOURCE: wd-65733 Mitsubishi Tv green blinking
You need a new projector bulb. Google up your model and buy the best warranteed one you cAN FIND. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!
Posted on Aug 13, 2010
  • 5138 Answers
SOURCE: I just replaced the blub on a Mitsubishi 65 inch
Ballast Board 1-800-638-3328
Posted on Oct 21, 2010
  • 1156 Answers
SOURCE: getting white spots on my
Hi,all HDTV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board and also white spots.
A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens.
The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
Good luck.
Posted on Jul 18, 2011
SD Tech
  • 14553 Answers
SOURCE: how do i replace the fans on a mitsubishi wd 65733 tv
Ok, I see for some reason this question is listed several times with somewhat different wording---I have a suggestion for you which may sound silly but can resolve your problem if what I think is wrong is wrong:
Take a look at this link, it is a question similar to yours and the answer cured the problem in this set----worth trying and cannot hurt--I would not do it in the house as a lot of dust is likely to be in set.
Please let me know if questions etc.
Posted on Apr 21, 2012
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WD 65733 TV. Red lamp light comes on after picture appears on screen.
Check this possible answer I provided and it worked for another similar set:
Posted on May 23, 2012
Mitsubishi DLP TV wd-73734 HAS WHITE SPOTS
Bad optical light engine, most expensive part in set
Dec 09, 2012 | Mitsubishi WD-65733 65" HDTV
65" 1080 mitsubishi tv model# WD-65733 wont turn on
It is probably the wiring. Try buying a new power cord.
If not than it is just malfunctioned.
Contact Mistubish
Nov 25, 2012 | Mitsubishi WD-65733 65" HDTV
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
''Mits'' WD-65733 blinking timer light
The green LED is blinking because there is fault in the TV you will have to take to a technician to determine the cause.
Nov 24, 2008 | Mitsubishi WD-65733 65" HDTV
Yellow status light on mitsubishi wd-65733 tv
When tv goes out, press the menu and input buttons. The green light will flash with a 2 digit code.
Jul 26, 2008 | Mitsubishi WD-65733 65" HDTV
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
