Question about ECM Giotto Espresso Machine
ECM Giotto Espresso Machine (original) Boiler wont fill
Hi my Giotto refuses to activate the pump to refill the boiler. I have just wired in a new Control Box. the pump works when I lift the brew head lever but it does not come on to fill the boiler. I have also replaced the level sensor in the boiler and rewired where the connections looks old. I have tested this circuit and I get the correct change in resistance when it detects water. Still no joy in getting the pump to activate when there is no water in the boiler. When I plug in I can hear the solenoid click indicating that is working. But when I measure the voltage across the terminals of the solenoid I only get 0.2V and it varies It is weird because the pump works with the brew lever and the solenoid appears to activate when the water level is low but why no pump?
2 Suggested Answers
  • 1618 Answers
SOURCE: Help w/ ECM Giotto. pump doesn't turn on when pulling lever
Replace the magnets in the water tank, the reed switch is not reading one of them, most likely the safety or bottom magnet.
Posted on Feb 03, 2010
Plumbing espresso machine
if this machine has a tank you fill for the the water it most likely will need some sort of lvl probe and inlet fill solanoid installed. best to check with manufacturer and see if your model originally had a model that could be hooked directly to water if not i would contact the company and see if they have the parts and if the control board in the machine has a fill circuit.
Apr 09, 2014 | ECM Giotto Espresso Machine
Ecm Giotto
Have you checked the Thermostat on the unit in the tank if it is stuck it will cause the tank to over heat and pop off the steam valve?? there should be some resettable overheat protectors as well. Has the preassure relief valve been replaced as well??
Feb 14, 2008 | ECM Giotto Espresso Machine
Sir, LA CIMBALI 39 DOASTAROM 3 GROUP MACHINE MOTHER BOARD BROKEN Sir, We try to install the new mother board, most of the things are working, the boiler is heating up, but when we turned on the...
hi. Im not sure excactly what is going on with your explaination about your machine, but I gather the the original mother board has died, and you have replaced it with a new one. It sounds like you have a water fill issue with your machine. If the boiler doesn't have enough water in it, then the pc board will shut the machine down. Ive never worked on a m39, but they are from the Faema corporation, and Faema/ La Cimbali electronics canbe very complicated. Dont now why they make such complicated electrics, cause there are hundreds of other brands with simple electrics.
If your boiler was empty, then the water fill cycle might be a timed cycle, and is shuting down before the water level has reached the water level probe inside the boiler. If this is the case, then once it has stopped, turn the machine off, wait 10sec, then turn it back on again and let it start the fill cycle over. You may have to repeat this a number of times until it has reached the water level probe inside the boiler. Some machines are designed to have a slow water fill, because when you draw hot water from the boiler for making tea, fresh cold water is pumped back into the boiler to replace what you have taken out, and if it fills too quick, then your steam pressure drops. So by filling slower, the machine will maintain its steam pressure. Good idea in theroy, but its only good for cafes that do 300 coffees per hour.
Im hoping that your machine is configered this way, cause it will probably just have to be turned on a few times until it has reached the water level probe as I explined in the begining. If you have a sight glass, you can check to see how high your water level is. If your level is correct, and its still not working right, then id recomend calling a repairer. There are number of things that could be wrong, causing your board to die. Faulty solenoids. switches, touch pads, pressure switches can cause main board issues. Hope all this helps with getting your machine working properly. Dazza Repairer
Oct 23, 2011 | Espresso RMI La Cimbali Espresso Machine
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Boiler bar gauge has no pressure
please check to see if its not sticking refill with water
May 04, 2009 | ECM Giotto Espresso Machine
Astoria SAE 1 trickle of water from hot water faucet
Some models have an economiser valve, which mixes hot water from boiler with cold from inlet line, that could be closed or obstructed. The line from the boiler to the solenoid or the pipe inside the boiler could be blocked.
Mar 20, 2009 | Astoria Argenta SAE-2 Espresso Machine
The water does not g through appear to get to the boiler
maqchine needs manual cleaning. Take apart and clean mechanically. Take photos first, wou will have problems assemling the spaghetti like pipework. Descaling chem does not help here./// Olev
Dec 25, 2008 | ECM Giotto Espresso Machine
When I pull the lever to make an espresso it takes about 10 seconds for water to come out. It's as though all the water in the boiler (or heat exchanger?) drains out when I dont use the machine for about...
Tank fills automatically with level electrode on top of boiler. Same punp that brews your coffee will top up the tank. Electrode full of scale - no water in tank. The boppom of group has drain exit. Fully normal to have a bit water to drain out. tale apart and clean manually! Nothing to be afraid of. take photos as it can get tricky to get all pcs back after mayor overhaul. Larger commercial machines have the drain outlet covered behind a vertical wall. You don't see the water but the E61 group is identical!! ///Olev
Nov 01, 2008 | ECM Giotto Espresso Machine
Boiler fails to fill
your water container is not put it correctly. make sure both black plastic bars on the container are flush with the metal rails that they sit on.
Mar 01, 2008 | ECM Giotto Espresso Machine
ECM Giotto Espresso Machine Logo
49 people viewed this question
Top ECM Coffee Makers & Espresso Machines Experts
Are you an ECM Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
