Is it possible to flash a Logik L24FED12 TV board with firmware for a Logik L24FE12 TV.
I uploaded a photo of my main board and was advised that it was a particular model and where i could buy one. I did this but after fitting the TV asks me to insert a DVD. My TV does not have a DVD drive. The two boards look identical.
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
Not possible. It will explode!!
Posted on May 12, 2017
Samsung tv which iv e had about 6yrs .it started sparking at the back and the picture went . Is it worth getting repaired or am best off buying a new tv
Sparks means short circuit to the main board of the TV, I would advise to get a new one also get the wall outlet checked before you install new one get the earthing checked too.
Jan 26, 2018 | Samsung Televison & Video
I need to replace the tcon board in my tv model # ELEFT466 What part should I buy?
Go to any TV parts supplier online and enter your model and make of TV, then follow the parts listings, the Timing Control PCB may be part of the main PCB.
Jan 17, 2017 | Televison & Video
Backlight inverter board for LG TV What is correct part to restore illumination to TV
LED TV Repair Tutorial - Common Symptoms & Solutions ...
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
LCD TV Repair Tutorial - How to Replace the Backlight ...
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore ‎illumination
Sanyo 42 led lcd tv - Engine cork
Jan 27, 2016 | LG Televison & Video
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
I have atoshiba 32 inch television and the motherboard gone bad. please give me places were to find a replacement ?
Well it depends on what the TV model is.
For the 32AV502R in particular if you can't find a replacement main board or if you are not actually certain the problem is in the main board to begin with it may be worth checking the failure symptoms and proposed repair service offerred here:
http://www.coppelltvrepair.com/p/427/repair-service-for-toshiba-32av502r-intermittent-shutdown-random-shutoff-not-powering
Hope that helps!
Sep 03, 2011 | Toshiba 32AV502R LCD TV
RF connector broke from board....looks like part number is 1519592K, but nothing appears when I enter that part number..how do I get new board?
You can't buy the RF connector parts from a TV component supplier as they are already soldered to the main board. A friend who can solder PCBs or a TV repair shop should be able to re-solder the original for you. If it's damaged, a TV repair shop might also be able to find another that will fit as they are fairly standard components. This will be far cheaper than buying a new main board and it's probably going to be difficult to get one.
I had a look for a new main board, but the TV is fairly old and I couldn't find one or a part number. It's easier to find components by part number rather than by TV model, so your best bet is to find the part number on the main board and try searching for that on Google or similar.
If you want to post back with the model number, I don't mind having a search for a replacement main board, but my advice would be to get the existing repaired, if possible.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | RCA MM36110 36" TV
Insignia tv shock power on/off on its own
I have experienced the same issues, I called Insignia about this particular problem, I explained that this TV shocked me and now won't work, there explanation is that because I was out of warranty there is not much they can do, never mind that they had a particular model that a recall with the same issues as there 26 inch model, when the TV shocks u, it's usually your main board gone bad,
All I can do now is complain on these boards and inform other consumers of how bad of a product this is and to stay away from this brand due to the fact have poor designs on these models.
I will continue to ***** and complain, on Facebook and other post until maybe someone listens and decides not to buy a piece of **bleep** like this, what a joke, will start a class action law suit, remember the more u complain, they will eventually have to listen to you just like they did with their 26 inch models they will do it for other models so hold on to your sets this one's due for a recall.
They also said that they can't find any threads on their insignia boards, just type shocked and u will find threads, and if u want to do a Google search type insignia and your model number and see how many threads u will find about their faulty boards, I'll be back to add these post with links of how much of a piece of **bleep** this TV really is..
Jan 30, 2009 | Insignia LCDTV26 26 in. Television
32'' Winbook Lcd Tv bad main board
eBay: Find WINBOOK LCD TV CONTROLLER BOARD 6870C-0060F in the Electronics
I located this board at anewparts on ebay, hope this helps you also
"Q"
'Til the Wheels Fall Off!!
Dec 26, 2008 | Televison & Video
Sony32fs120
1. Try your Memory to replace.
2. Check all estated voltage in each particular section.
3. TRy also to replace your MICOM / System IC if your Confused.
Feb 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Samsung SP42W4HPX
convergence boards for a tv are kind of hard to come by after 3 years old where did u buy the tv? if from sears you can goto the site and look up the parts or contact the manufactuar directly on there site for a parts section. www.samsungparts.com i tried to look up your model number said it was invalid try that and good luck also convergence boards have a dcu on the board looks like a small motherboard and u might have to take the old one off and put it on the new one with solder GL hope it helps
Mar 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
