Question about Cell Phones
How can I reset my mobile gmango if switch off
How do i unlock Gmango forgotten password phone
Do u use windows 7.1 or upper version. I think This will help u.
If you can turn off the phone do it. For unresponsive or frozen phone, remove the battery and put it back again after few seconds.
1. Press Volume up button and hold then press Volume Down button and hold and then press the power button (briefly) to switch the phone on.
2. Keep holding the volume up and volume down buttons until you see a reset screen option.
3. Now follow the instructions that will show up on your mobile screen to factory reset your phone.
Feb 01, 2015 | Cell Phones
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
Apr 16, 2014 | Samsung Computers & Internet
Reset switch
hi , that could be a faulty reset switch, I come back later and give you a more complete reply as i run out of time now.
Regards
GeWiz
Feb 10, 2013 | Pride Mobility Products GoGo Ultra X...
I have set a password and forgot it when switching on my phone how can i reset it
What is your mobile and model ?
If you forget the security code means get the master reset code for your mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, if you use nokia or alcatel mobile means get the master reset code from this site http://www.mobileunlocksolutions.com/unlocking-services/rs1wp6/ , it has the best services for the master reset code for your mobile.....I hope this may helpful to you.........
Aug 21, 2011 | Cell Phones
In my nokia 6600 mobile phone bluetooth not working these days
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.
or try this(But it will fully format your phone)
Method 1: Three Finger Reset for Nokia Phone 1. Switch off your Phone. 2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key. 3. While holding The Three buttons, press the power button for switch on the phone. 4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2: Hard Format of Nokia Mobile Phone 1. Switch off your Phone 2. Now Press following key-*#7370# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3: Soft Reset of Nokia Mobile Phone 1. Switch off your Nokia phone 2. Now Press following key sequence *#7780# 3. Enter Default lock code is 12345. 4. While holding All of the buttons, press the power button for switch on the phone. 5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Please Note: The formatting method will erase all of your Phone data. Please take a backup before you Format.
Dec 16, 2010 | Nokia 6600
I want restore own mobile but my mobile need lock coad
Dec 11, 2010 | Nokia 6600
Always restarting
Try to reset your phone :
Dec 06, 2010 | Nokia 6600
No application manager
Reset your phone:
The default lock code is 12345.(Read Method 3)
Method 1:
Method 2:
Method 3:
Please Note:
Nov 09, 2010 | Nokia 6600
My 6600 keeps on sending mms
Reset your sofwares :
Method 1:
Method 2:
Method 3:
Please Note:
Nov 05, 2010 | Nokia 6600
My n70 is hanging while switching on the mobile.
Just remove ur memory card
then switch on the phone
If not working
reset ur phone
if u wanna help to how to reset
replyme
May 08, 2010 | Nokia N70 Cellular Phone
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
