Question about Electrolux Washing Machines
Electrolux T5550 coming up with error Jumper 1, what does this fault Code mean?
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Posted on May 20, 2009
protek480
  • 1723 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 25, 2009
ZJLimited
  • 17970 Answers
SOURCE: Fault code EF is flashing
EF on the Electrolux refrigerator digital display means "evaporator fan."
The long answer is, it doesn't necessarily mean there is something wrong with your Electrolux refrigerator.
Turn the power off on the digital display and carefully unplug the refrigerator from the power source. Leave the refrigerator unplugged for three to five minutes. Plug the refrigerator back in and give the refrigerator a few minutes then turn the power button back on. Press the default button on the display and see if the EF code goes away.
Electrolux recommends that you do not plug the refrigerator into an outlet that has a reset button. If your refrigerator is plugged into one of these outlets, try plugging it into another outlet and see if the refrigerator resets itself.
Hope this helps.
Posted on Jul 21, 2011
SOURCE: I have a Electrolux range oven and I did a self clean and it faulted through the cycle. IThe code that comes up is "--" which the manual says it mean cooktop lock. I fred to unplug / turn breaker of
reheat the oven and then put it in the washing machine
Posted on Jan 01, 2012
  • 52123 Answers
SOURCE: E4 error fault code on a electrolux blast chiller model RBC101. What is it?? Thanks a lot
what is a blast chiller .
Posted on Mar 03, 2016
How do i fix electrolux dishwasher when error code 1 is flashing
Hello friend, thanks for your post!
I see your Electrolux dishwasher is displaying an "E1" error code. "E1" stands for a leak detected which means your dishwasher base has detected a leak. If you can't see a leak you may want to perform a reset on your dishwasher you can do that by disconnecting the power from your appliance for roughly ten minutes.
If that does not correct the issue you may want to seek assistance from a technician. They would need to come out to diagnosis and repair your dishwasher. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux Dishwashers
What e54 error code mean on an electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E54 - means the motor is inoperational.
Could be:
  • Excessive wash load.
  • Voltage too low.
  • Motor/transmission system inoperative.
Dado
Aug 09, 2014 | Electrolux Dryers
E64 error code electrolux dryer
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
What is error code 1 mean?
Good Morning Friend,
I understand you are receiving an error code "1" on your Electrolux dishwasher. Error code "1" is a leak detector. This does not necessarily mean that there is a leak. This could be a false code. I suggest resetting your appliance, by either unplugging it or shutting the power off at the circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 19, 2014 | Electrolux Dishwashers
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Sep 25, 2009 | Electrolux EIED55H Dryer
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
48 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
