Question about Kipor Electrical Supplies
Kipor kde 20ss3 refuses to start and signaing p-05 fault. any hint please
adnanbhatti
  • 1188 Answers
SOURCE: Kipor 6700TA displaying charge fault (P5)
Check for loose or rusty battery cables. Unscrew the rear cover and locate the red battery wire. Disconnect it and, using a multi meter, check its resistance: it should have a very low value. Do the same with the other wire.
Start the generator and remove battery wires. If the voltage between them is zero then a fuse is blown.
Next open the front panel (where the display is), there you will find two blue wires with covered fuses, check and replace those fuses if found faulty.
If the problem is still there then it could be the charge regulator. Open the back cover by removing the six nuts. Near the edge you will find a component with silver cover resembling plates. There are three wires leading from it. Check resistance between these wires (one by one) and its body: it should be infinite, if not then replace it. remove the charge regulator and take it to a generator spare shop. The person there will further inspect it and will tell you if you need to replace it or repair it.
Hope this solves your problem.
Thank you for using fixya!
Posted on Aug 20, 2009
sal_kh_sab
  • 98 Answers
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Posted on Oct 25, 2009
Testimonial: "Khan sb. truly is a professional. "
  • 144 Answers
SOURCE: I have a Kipor KDE
Hi, I hope I can help a little bit. The hunting by the governor like can be caused either by governor adjustment or carb adjustment might be the culprit.But before you go into that, have you checked and cleaned the air filter or looked at the carburetor that might need cleaning if it has been awhile since that was addressed? If you figure that is alright try adjusting the carb first. I have never seen or heard about that brand of machine before, so I will give you a general adjust procedure. I will stress again to check everything you can think of first. The fuel tank has to be vented and on most machines this is done by the tank cap so make sure that is OK. Is the filter on the fuel outlet of your tank not obstructing the fuel flow and that the fuel lines are in good shape and not starting to deteriorate inside and slowing fuel flow?
To adjust the carb make small 1/8 of a turn at a time. Before starting the engine turn each one of the low and high clockwise or in until lightly seated so the needle seat is not damaged and remember that setting, even mark it down so you can always come back to that setting. The low or idle mixture screw should be about 1 turn out or counterclockwise more or less. The high mixture screw can be anywhere from 3/4 to 1 1/2 turns out or counterclockwise. Do not adjust the high mixture screw less than about 3/4 turn from the seated position. When you turn these screws in or clockwise it lets in less fuel to air and could make it run too hot.
Start with the high speed mixture screw and turn 1/8 of a turn out and listen what happens. If not better do that again up to one full turn in 1/8 increments. No good results try the low speed or idle mixture screw in 1/8 increments and see what happens. If no good try with the two at the same time.
There is one more screw and that one is on top of the carb and adjusts the idle or low speed of the engine with no load and is also very important to adjust the right idle RPM so that when a load is turned on it has enough RPM so the engine has enough so it does not start to miss and sputter because of turning too slow.
I have given you all this info without knowing if this is the right type carburetor or if this engine is gas or diesel, or is a barrel type carb.so I hope this helps you out even just a bit. All the best and good luck. By the way I will not even try to explain the governor setup as It is too lenghty and I don't want to make it run worse or not at all.
Maybe one of the other guys might have a simple procedure to get it done. Well good luck and all the best to you.
Posted on Feb 05, 2011
  • 93 Answers
SOURCE: Hi, I from Indonesia and I need help... I have
maybe your generator has a problem with the cylinder head gasket.try to remove the cylinder head gasket,grind the valves intake and exhaust it. use the gasket cement to glue the cylinder gasket then assemble it
Posted on Feb 24, 2011
SOURCE: Iam looking to download a manual for a Kipor KDE
Try this link:
http://americanrvcompany.com/assets/images/Kipor/KDE5000ETA%20Operation%20Manual.pdf
Posted on Sep 21, 2015
I have diesel generator Kipor kde 19 STA3 . It keeps shoutinng dowen after it starts
First check the oil, A low oil sensor will shut it down if more than a quart low. Then drain your water separator and change fuel and air filters. Anything outside of that is going to be mechanical (lift pump, injection pump)
Jul 17, 2017 | Cars & Trucks
Hi, My KDE 6500T wont start, i replaced the battery and when i switch start, i can hear a tick but no ignition ,and the battery cable become tooo work
Check engine isn't locked down, rotate by hand, then check starter motor, and solenoid. The click you hear is probably the solenoid clicking in.
Feb 24, 2015 | Kipor Electrical Supplies
What could be the problem if KIPOR KDE 6500T Diesel generator turns off when I switch the breaker on?
is it air bound , clear it out , or you have a short but I would go with the latter ,
Dec 03, 2014 | Cars & Trucks
Kipor kde 6700ta GENERATOR
There is, on most generators, a fuse of approximately 8Amps in series with the charge system for the battery.
If the generator produces AC and there is no charge to the internal battery, I would suspect the altenator winding, diode pack or regulator.
Nov 14, 2013 | Computers & Internet
Hi, I from Indonesia and I need help... I have Kipor KDE 6700T that can starts but produce lot of smoke (white) and consume more fuel,,, Please how solve that problems
Feb 24, 2011 | Electrical Supplies
Aug 04, 2009 | Kitchen Appliances - Others
Electrical Supplies Logo
213 people viewed this question
Top Kipor Electrical Supplies Experts
jhnolson
Jay Finke
Jay Finke
ray gallant
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
