Question about LG Refrigerators
I need to know the part number of bottom door hinges, bracket, bushing and cam of my LG Refrigerator GR M602YLQ and from where i can buy it in Riyadh, Saudi Arabia.
SOURCE: I am in riyadh saudi arabia.I have a 2Mbps speed
first check with the speed checking website from ur ISP website
Posted on Oct 09, 2009
maxtreadmill
  • 832 Answers
SOURCE: Competitor Delt Machine CDM 197: Hello do you have this product: Yukon Fitness Co...
Here is the international number to reach Yukon fitness:
All International Customers and Customers
outside the Continental U.S must contact us by phone or facsimile to obtain shipping cost information.
By Phone: 001-440-439-0000
By Fax: 001-440- 439-0030
Posted on May 14, 2010
nzrhusain939
SOURCE: I am in saudi arabia
what MTP
Posted on Dec 26, 2012
SOURCE: ZIP CODE OF RIYADH SAUDI
I M LOOKING FOR THE POSTCODE OF MAKKAH CITY SAUDI ARABIA.
Posted on Aug 29, 2013
gopakumarg43
  • 73637 Answers
SOURCE: Where is the maintenance center in riyadh, Saudi Arabia for magic chef refrigerator? Model no GT2182NKCW
At the exact center of Soudi Arabia.
Posted on Feb 24, 2015
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • Jul 25, 2011 | Refrigerators
    The freezer door on my top-mount no-frost refrigerator comes open every time you shut the bottom door. What is the problem????? Before I purchase another brand...
    The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
    Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
    Dec 26, 2010 | GE (GTS16BBS) Top Freezer Refrigerator
    I have a frigidaire refrigerator with top freezer. model frt21nfrd2. About 12 years old. With a light inside you can see light in the top right of the refrigerator door. Seems to seal good every where...
    remove freezer door. now remove hinge on top of bottom door. lift bottom door off. now place a washer on bottom hinge and re install everything. this should solve your problem.
    Feb 01, 2010 | Refrigerators
    Freezer door opening when refrigerator door closes
    Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Jan 10, 2010 | Amana ABB1927DE Bottom Freezer...
    The left side door has dropped and the piece that closes the gap between the two doors will not operate properly. It leaves the gap open and the refrigerator looses coolness. Need to know how to realign...
    Check the lower hinge of that door for a broken closer cam. The upper hinge is adjustable and adjusting the corners in the front will shift the cabinet to align the door also.
    Eric
    Dec 11, 2009 | Samsung RF265AA Bottom Freezer French Door...
    We'd like to change the door from left opening to right opening on our refrigerator
    Good day,
    Before proceeding there are a lot of buttons and cover emblems that cover screw holes. Remove by prying off with a small screw driver as needed. As well, remove all food etc.
    As well, keep track of all bushing and shims holding the door hinges in place.
    1. With the top door closed, remove the top bracket. Open the door with both hands, open approx. 1 foot and lift off.
    2. Remove the middle bracket, and remove bottom door as in step one.
    3. Remove and reinstall handles on the opposite side of each door.
    4. The bottom support bracket must be removed, and remounted on the opposite side, with the pin sticking up.
    5. Reinstall in reverse order using bushing and shims as needed to assure correct alignment.
    Dec 01, 2009 | Kenmore Refrigerators
    I think the hinge has sprung on the frig door. it
    check the door hinge brackets there are plastic bushing they may be damaged causing the door to have slack in it open the door and take the handle and pull it towards you there should be no slack if there is it could be a bushing or just a loose hinge
    Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Bottom freezer popping open on its own
    Sep 21, 2009 | Refrigerators
    The freezer door won't stay shut, thanks for any help
    Look to see if the fridge side door rises up about a quarter of an inch when you open it. If it does see if the freezer side does. If it don't you may have a door closing cam which has broken. It's on the bottom hinge, is black plastic and can be replaced without removing the door.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
    Aug 05, 2009 | LG LRSC-26930 Side by Side Refrigerator
    Right Door is making loud popping noise
    After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
    Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerators Logo
    37 people viewed this question
    Top LG Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Colin Stickland
    Colin Stickland
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
