Question about LG Heating & Cooling
H have a lg LST 243h air con and I cant seem to get it to blow hot/warm air. the remote beeps for all other functions except on the one that looks like a sun please help
  • 47 Answers
SOURCE: air con just blows hot air s type jag
With the key in the off position; remove the RDO BAT fuse for at least 10 seconds then replace the fuse; turn on or start the vehicle and try the A/C again. Removing the fuse should reset blend actuators
Posted on Apr 24, 2009
Sparky2012
  • 102 Answers
SOURCE: my ptac is not blowing hot air only blows warm air
freon is low or outside is very cold
Posted on Dec 04, 2009
  • 239 Answers
SOURCE: 99 chevy silverado heater doesn't blow hot air,
CHECK TEMP. ACTUATOR MOTOR
Posted on Dec 08, 2010
richroth
  • 9472 Answers
SOURCE: Hi I have an lg
Error C6 on lg cool art is common. You need a new CAPACITOR. cost $7.05c aud. it's 6uF 450vac.
take about less than 10min to install.
C4 is for over heating. This should clear after the capacitor is replaced.
Posted on Jan 15, 2011
oneStan
  • 430 Answers
SOURCE: Hi, The air con in my 2003 Audi A6 1.9 tdi 130 is blowing warm air the air con rad is fully gassed and all fuses are ok . Thanks in advance for any advice on how to fix
The only other thing then would be if the compressor is turning, engaging, and the cooling fan working properly. You should either be able to see the compressor clutch engage, as the switch is energized, or at least hear it click loudly when the switch is energized. If it is not, then there are sensors for the low pressure/high pressure line to tell the compressor when to function, that also have to be checked.
As the engine runs with the compressor turning, one line should be hot/warm, the othe,r (larger diameter hose) should be cool/cold, if the system is working properly.
If the compressor is turning when you have the A/C turned on, then see if the cooling fan is running as well. It must run to remove the heat and cause the process to function properly.
Posted on Mar 28, 2012
Mar 27, 2012 | 2003 Audi A6
Cant get remote to function even after replacing batteries
You can test your remotes infrared with a camera . Press the buttons on ac remote . look through your camera phone and see if the end lights up when your press buttons. does your remote beep .
You can get replacement universal remotes
Jan 30, 2012 | LG Heating & Cooling
The remote has "frozen" and
If the remote has been in use for a long time then some moisture and dust has accumulated in the contacts. Try this simple remedy: Take out the batteries from the remote. Keep it in the open for sometime - not directly under the sunlight. Let it get dried up. Blow some air inside. Wait for some more time. Replace the batteries. If it still does not work I am afraid you have to replace the remote
Sep 22, 2011 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
Split system air con LG model LST 2434C-2 unit won't turn on, remote is working but unit won't respond, turned on at wall.
Check there will be red icon when power is on,before switch on by emote. If no red light, there is no power goes into indoor unit. Check. If red light is there and no response with remote, communication error between remote and PCB in indoor. Try with other same type remote. If yes, replace battery or replace your remote. If no, receiving sensor in PCB problem. Repair or replace it.
Jan 13, 2011 | LG Heating & Cooling
Cant make it blow out hot air.
You do not mention the model. Most aircon remotes have a mode button which has three or four icons. On cooling there will be a ice crystal icon on the lcd display. Pressing the mode button (sometimes behind a cover on the remote) this icon will change. You want to set it to the "sun" shaped icon
Jun 02, 2009 | LG Heating & Cooling
LG LSK 243H-1 Air COnditioner
Hey, all I know is 100*c= 212*f 50*c=100*f so 30*c=50-60*f try to change your centigrade to fahenheit! thank you very much!
Aug 26, 2008 | Heating & Cooling
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
