Question about PRINTER Office Equipment & Supplies
My laser-jet printer 600 602m displays maintenance kit low how can i reset it to factory setting to erase this massage
  • 2072 Answers
SOURCE: Maintenance kit for Xerox 8500
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
mbase213
  • 728 Answers
SOURCE: i cant install hp laser jet 1018 on this board
Hi h_kanani1366,
It doesn't sound like your problem is with the printer, it sounds like your problem is with the USB drivers for the motherboard. Look in Control Panel and click on System, then click on the Tab that's says Hardware, From there click on Hardware Devices, and when it opens look down on the Systems configuration area and look for a ! in a triangle. If you find one then the problem is the driver. You'll need to go to the manufacturer's site for that Motherboard and download a new USB controller driver, or sometimes there call Chipsets drivers. And that should fix your USB port, if the drivers aren't the problem, then could have a faulty motherboard. Try putting something else that you knows works into that same USB port to see if you get the same response. That will let you know if it's the motherboard, or it could be the Printer or the Cable that your using to connect to.
That's it my friend, there can be no other reasons I can think of.
Good Luck,and don't forget to leave a rating based on my solution.
Thanks Mark
Posted on Apr 09, 2009
  • 48 Answers
SOURCE: PERFORMING MAINTENANCE ON HP LASER JET 4050
I do recommend a maint. kit ( p/n # C4118A). to clear the maint. messsage, turn the printer on while holding down the left item and left -value key, when you see reset maint. let go of the keys..
Posted on May 28, 2009
mishrajk21
  • 202 Answers
SOURCE: HP color laser jet printer is displaying error
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
Posted on Aug 10, 2010
  • 1138 Answers
SOURCE: I need to reset (
Here is a link to the manual if you don't have one:http://www.dtxperience.com/documents/Manuals/DTXPRESS_IV/DTXPRESS_IV_Owners_Manual.pdf The procedure is on page 35.
Posted on Nov 16, 2010
How to reset hp printer laser-jet 600m 602 maintenance kit
1. Press the Home button on the printer's control panel.
2. Open the "Administration" menu.
3. Select "Manage Supplies".
4. Select "Reset Supplies".
5. Select "New Maintenance Kit".
6. Select "Yes" to reset the maintenance kit counter.
May 09, 2017 | HP Office Equipment & Supplies
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
How to reset fuser error for hp color laser jet 4650
First make sure it is the correct fuser for that printer. Turnthe printer off. Now turn the printer on and when the memory starts to count inthe display, hold and keep holding the green check mark button on the rightuntil all three lights come on solid. Release and use the down arrow to scrollto New Maintenance Kit and hit the check mark button. Hope this will help you.
Oct 21, 2011 | Office Equipment & Supplies
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
80 maintenance infoprint 1125
You need to replace your Maintenance kit and reset the fuser count.
This counter is reset by the servicer after a “80 Scheduled
Maintenance” message displays (300K copies) and a maintenance
kit is installed.
1. Select Maintenance Count Value from the Diagnostic menu.
Select Reset Maintenance Count. Pressing Select resets the
maintenance page counter to zero. Reset Maintenance Count
screen.
the operator panel.
The tests display on the operator panel in the order shown:
• Print Registration
• Print Tests
• Hardware Tests
• Duplex Tests (If installed)
• Input Tray Tests
• Output Bin Tests
• Base Sensor Test
• Printer Setup
• Error Log
• EP Factory Defaults
Sorry English only.... hope you can read English or google translate it...
Feb 24, 2010 | IBM Infoprint 1125 Laser Printer
Mar 29, 2009 | HP OfficeJet J4580 All-In-One Laser...
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Top PRINTER Office Equipment & Supplies Experts
Hardeepak Bhambh
Hardeepak Bhambh
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
