Question about Garden
Cadet model 1046 - Garden
5 Suggested Answers
  • 3 Answers
If the head lights come on, check the PTO switch connector. Very often the connector comes loose.
If no headlights, check the fuse. If blowen look for shorted wiring: Mice may have chewed wires inside the flywheel cover; check the head light cable. Often it rubs through at the hood pivot; check the lead on the carburetor solenoid, sometimes they rub through at the wire ties holding the red lead to the solenoid.
I am a certified Cub service tech,and those are the common problems I have run into.
Oh, one more thing, make sure the battery is good. Load test it or have it load tested if you don't have a tester. Don't just check it with a volt meter. That wont load the battery to check for dead cells.
Posted on Oct 30, 2009
  • 4 Answers
SOURCE: My Cub Cadet will not start. There is a green
Posted on Jul 02, 2010
  • 6468 Answers
SOURCE: how do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Posted on Aug 12, 2012
  • 48 Answers
SOURCE: How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
Posted on May 11, 2017
Have a Cub Cadet riding mower that will not go in reverse or forward. Model 13AP11CH709 and says 1046 on it
Serious tranny issue needing repair. Check the obvious - linkage connected?
Aug 22, 2017 | Cub Cadet Garden
Need a picture showing where 2 springs for manual pto go on cub cadet model LTX 1046. Kohlers engine, 2009-2011
you will need your specific model number found on the plate under the seat. Simply go to the correct parts section and there is a blow up of the area you are working on.
Jul 27, 2016 | Cub Cadet Garden
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Where is the fuse on a 1046 Cub cadet?
behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
Sep 01, 2014 | Cub Cadet Garden
For some reason, our Cub Cadet riding mower 1046 will not start. The battery is o.k. Where are the spark plugs? What could be wrong with it?
Aug 15, 2012 | Cub Cadet Garden
How do you remove the pto on Cub cadet LT 1046?
Aug 05, 2012 | Garden
PTO will not engage onLt 1046
check the safety switches start with the one on the seat
Jun 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Reattaching drive control pulley spring to Cub Cadet 1046 Mower
One quick tip.. change the oil often in the first year..there is a sensor that will stop it from running.. its something you can avoid by simply changing the oil and filter -what will seem like too often -- but its worth it.. NOT having to haul it to the repair shop for them to fix it!! I was told about this tip by a 1046 owner that had to pay to have hers fixed..I have done mine often in the first two once a year..
Sep 12, 2017 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
