Question about Garden
How .to change drive belt club cadet 1046 - Garden
3 Suggested Answers
  • 689 Answers
SOURCE: where can I download a free service manual for a cub cadet lt 1046
Manuals Online.Com
Posted on Nov 05, 2012
  • 43 Answers
SOURCE: How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
Posted on May 11, 2017
May 11, 2017 | Garden
Mower ran fine, put it in the garage Started this weekend and the back wheels are locked up.
    2014 - Cub Cadet LTX 1046 KW - 21.5 HP Kawasaki 46 ...
    www.georgiamower.com/cub-cadet-ltx-1046kw-2014
    The Cub Cadet LTX 1046KW Series Lawn Tractor is one of the most innovative and ... pdf, 2013 Cub Cadet LTX1046KW, LTX1050, LTX1050KW Owners Manual ... 2012 - Husqvarna YTH22V42 - 42 Inch Hydrostatic Riding Lawn Mower.
Jul 31, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Why would my belt on my cub cadet 1046 mower keep popping off?
Did you put all the belt keepers back on? I find a lot of DIYers usually leave one off thinking it is not important.
Jun 30, 2015 | Cub Cadet Garden
How to change a drive belt on a ltx club cadet
yep lots of sweat will get in your eyes under it remove mowing deck first then it won't be in the way
May 14, 2015 | Garden
Idle pulley off a Montgomery ward 16-42 7 speed will work on a club cadet mower
You need to spec it out to know if will. Diameter, Height, offset, and if it V groove or Flat. In most cases they don't swap out that easily as Cub Cadet (MTD) products are usually very picky about these things just like their belt sizes.
Jan 29, 2015 | Garden
Where is the fuse on a 1046 Cub cadet?
behind the dash right side try to jump starter if catch then try then go to starter silinoid jump it will try to start if doesnst replace it if dose work go to switch relay beehind dash near fuse let me no what happen
Sep 01, 2014 | Cub Cadet Garden
How do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Aug 05, 2012 | Garden
Installing a drive belt on a club cadet 1330
hopefully this is what your looking for >>>> http://www.partstree.com/parts/?lc=cub_cadet&mn=1330+S%2FN+207%2C401+-+239%2C300&dn=0021700029
Sep 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Reattaching drive control pulley spring to Cub Cadet 1046 Mower
One quick tip.. change the oil often in the first year..there is a sensor that will stop it from running.. its something you can avoid by simply changing the oil and filter -what will seem like too often -- but its worth it.. NOT having to haul it to the repair shop for them to fix it!! I was told about this tip by a 1046 owner that had to pay to have hers fixed..I have done mine often in the first two years...now once a year.. http://diylawnmower.blogspot.com/2012/07/cub-cadet-manuals.html
https://www.emanualonline.com/Other/Cub-Cadet-LT-1046-Factory-Service-Repair-Manual.html?currency=USD&gclid=EAIaIQobChMI_9Sr672e1gIVyCSGCh0vgQxyEAYYASABEgKqDfD_BwE
Sep 12, 2017 | Garden
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
