Question about Orange Computers & Internet
Autoloader MT 3581 display panel is showing orange with an !
3 Suggested Answers
SOURCE: Error on IBM 3581 tape library.
Error 5 might be the drive motor might be faulty.
Posted on Oct 15, 2008
  • 6 Answers
SOURCE: no power on IBN 3581 L28 Autoloader tape drive
I believe you can get Repair / Power supplies from
Posted on May 06, 2009
Unable to get system manager-Autoloader to ID the media discs. Doesn't show any option for media type. Only sees 120mm standard.
If the autoloader is in ready state, reboot the PC. Check if system manager displays the autoloader drives and printer. Check the firewire cable. It's easy to plug it in backwards. The firewire card can get damaged if it was plugged in backwards.
Aug 18, 2014 | Rimage 2000I Computers & Internet
Rimage 3400 auto loader
R U sure the firmware update was the correct update and that it installed successfully? Check in the firmware part of the burning program to obtain a list of the currently installed firmware.
Apr 07, 2014 | Rimage Professional 3400 NSS CD/DVD...
3581 Err 7
Cartridge compatibility problem
Dec 23, 2011 | IBM 3581 Ultrium Ultrium Tape Drive
Executing OTP version 3.04
Hook a VGA monitor, keyboard and mouse up to it. Then turn it on to see if it's booting into Windows or even into the BIOS. If it's booting into Windows, then download your autoloader firmware from (click the support link, then your model, download the autoloader firmware) -- then unzip it somewhere on your Rimage and use Gemini Utilities to update the firmware in the autoloader. Then restart the computer and see if you still see the same message.
The printer being recognized is tied very closely to the autoloader firmware working. Also, it helps to make sure the printer's switch is set to the position marked for Transport.
Apr 15, 2010 | Rimage DiscLab DL5200 (555101120) Burner
Forgot service password for HP Surestore Tape Autoloader 1/9 DLT 1 Tape Drive
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Mar 08, 2010 | HP Surestore Tape Autoloader 1/9 (C7147A)...
No power on IBN 3581 L28 Autoloader tape drive
Mar 23, 2009 | IBM 3581 Ultrium Ultrium Tape Drive
3581 Autolder problem
You can try i send my IBM 3581-H17 there for repair and upgraded from IBM 3581-H17 to IBM 3581-H23.
They do advance replacement too.
Dec 29, 2008 | IBM 3581 Ultrium Ultrium Tape Drive
Error 5 states that there is a problem with the drive and not the library, either the tape path or read/write head. Replaced drive - works fine
Apr 01, 2008 | IBM 3581 Ultrium Ultrium Tape Drive
Adic faststor2
Try changing the autoloader SCSI ID and the tape drive SCSI ID at the front panel:
Use this option to view or change the SCSI IDs used by the autoloader. The autoloader occupies two SCSI
IDs, one ID is assigned to the autoloader and the second ID is assigned to the tape drive.
The default SCSI ID for the autoloader's SCSI controller is 0. The default SCSI ID for the tape drive is 5.
You only need to change a SCSI ID if there is another device, or devices, already assigned to these IDs.
NOTE: This option is primarily used if the autoloader is in an error state. However, any
backups that have not been verified as complete should be considered lost.
NOTE: If you changed the SCSI ID, you may also need to cycle power on the host
system and reconfigure your backup software before you can use the
autoloader. Consult your hardware and software manuals for more information.
Dec 27, 2006 | ADIC FastStor2 LTO (90024202)
Computers & Internet Logo
23 people viewed this question
Top Orange Computers & Internet Experts
Computer Repairing
Computer Repairing
Cosma Papouis
Cosma Papouis
Sandy Moore
Sandy Moore
Are you an Orange Computer and Internet Expert? Answer questions, earn points and help others
