Question about Garden
Honda 2417 HME ride on lawnmower cutting deck
Cutters keep going when the yellow lever is pushed down for disengagement. Is it a belt problem or the brake or some other problem?
5 Suggested Answers
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
How to reset brake warning light on 01 volks beetle
Brake warning? U mean parking brake light? Push the parking lever all the way down to disengage the switch if that doesnt work then pull the cover for the brake handle the switch is just below the lever u might have something stuck to it or ur have a faulty switch
Feb 14, 2015 | 2001 Volkswagen Beetle
Where is the freewheel lever located on the jazzy 1113?
Original Jazzy Select has push-down levers on each side behind powered wheels. These manually disengage the brakes on each motor individually. They are about 6 inches long and push down an inch or so. I don;t know about other more current models, The 2 smaller wires to each motor disengage the brake when given power (24 volt, I think). The 2 larger wires run the motor.
Jun 17, 2012 | Pride Jazzy 1113 ATS Indoor Power...
Front brake does not completely disengage. lever is lax, brake light stays on. fluid level ok.
Are you sure the brake is not releasing? Disc brake pads do not pull back from the disc like drum brake shoes pull back from the drum. They hold a slight contact with the disc to keep dirt and water off the disc and the pads. That's why disc brakes work so much better than drum brakes in wet conditions. I suspect that your brake lever and the pivot pin are worn and need replacing. How much up and down movement does the lever have? The plunger in the brake master cylinder pushes the lever back but the lever operates the front brake light switch. If the lever and it's pivot pin are worn, the lever will not come back far enough to depress the switch.
Good Luck
Steve
Aug 31, 2011 | 2000 Harley Davidson FLSTC Heritage...
I have a 17 HP 42" craftsman mower. When I disengage the blade lever, the blades do not fully disengage until I slow down the engine with the throttle lever. This has only begun recently. The tractor...
There are blade brakes, one on each blade pulley. You will need to check that the brakes are in good working order and that the springs holding them against the pulleys are in place. Also there is a spring to return the idler pulley to the neutral position. The spring could be broken or the idler pivot rusted not allowing it to return to fully neutral position. This should get you going down the right track. Hope this helps; please vote yes. Thank you.
Nov 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Parking brake light keeps fashing on and off and at the sametime the day time lights flash as well.
The daytime running lights go off when the parking/emergency brake is engaged. There is a switch located on the parking brake lever to tell the car the parking brake is on. It sounds like that switch is intermittently indicating the brake is on. Make sure the lever is all the way disengaged. Move it up and down, jiggle it to see if you can get the light to go on/off. If the lever is disengaged you probably have a bad switch or bad wiring to the switch.
Apr 20, 2010 | 2003 Dodge Intrepid
My park break light wont stop beeping
I would check to see if the lever is fully disengaged(pull up on it while pulling the release or push down if it is a hand brake lever while pushing the button) if it is fully disengaged then I would look into changing the switch or checking the ground to see if it is good buy cleaning the switch contacts.
Feb 06, 2010 | 2003 Buick Rendezvous
My toyota t100 broke down in a parking lot while i was driving. i pushed it into a parking space and put it in park and engaged the parking brake. later on that day i attempted to move my truck but when i...
Either remove the drivers side rear wheel and disconnect linkage or cut the cable from underneath (do this as a last resort... if you want to keep your emergency brake for future use, you'll have to replace the cable.)
Jun 10, 2009 | 1993 Toyota T100
Can't get stick to move down to disengage, push with all my power
With the engine off, reach under your deck and pull on the belt. This will force the idler arm back into disengaged position so you can start it. You can probably free the mechanism up with penatrating oil by spraying the pivot point on the idler arm ( the bracket the idler is mounted to that moves back and forth) while alternatly engaging the lever and pulling the belt till it frees up and returns by itself.
May 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
632 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
