Question about Car Audio & Video
Speed o meter was not working when i installed the stereo system with back view camera from local market speed o meter start working. but after 1 week there is sensor light and car is very heavy n not shifting the top gear. I scan and get the following errors: p0411, p0787, p0973, p0976, p2769 n P2764 all for "SOLENOID CONTROL CIRCUIT LOW VOLTAGE" Now the problem is happen somtimes n somtimes its gone.
    President:
  • 1,129 Answers
Jack up the front of the car and support with jack stands then proceed to check all connections going to the transmission, it is a good idea to unplug the connections inspect and reconnect, if the problem still persists replace the speed sensor on the transmission. If the connection pins appear corroded in any way spray out with electrical cleaner and repeatedly plug in and unplug 4 - 5 times this usually wears off the corrosion returning good connections. You also may have loosen up a wire behind the dash related to the speedo, check the plug connectors back there if you can crawl under the dash and manage to see the connectors, you may need to remove the instrument cluster to do this, it is a good idea to puchase a haynes repair manual to guide you through such a job.
Posted on Jul 25, 2009
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
Photos to dark
The aperture and shutter speed setting depends on the amount of light and on the effect you want to achieve. For any given lighting situation there are many possible aperture/shutter speed settings that are all equally valid. However, the aperture also determines the depth of field, and the shutter speed can either freeze action or allow it to blur. Only you as the photographer can decide which of those valid exposure settings best conveys your vision.
As to how to determine the proper exposure, there are several possibilities. One is to use a light meter. If you don't have a separate light meter, you can use another lens and meter through it. It may not give you exactly the same field of view, but it should get you into the ballpark. Then there's the "sunny-16 rule." This says that under a bright sun, the proper exposure is f/16 with a shutter speed equivalent to 1 over the ISO. Of course this is just a starting point, and you can adjust the aperture/shutter speed to achieve the desired result.
I suggest you visit your local library. They should have introductory books on photography which will explain all this in depth.
Mar 06, 2012 | Tokina f/NIKON- 80-200/4.5-5.6 SZX Zoom...
I installed in my vehicle this head unit and everything seemed to work fine intially. Howevver, when I put the car back together and went back to setup the bluetooth feature for my phone, the entire...
Sounds like it could be a setup issue (software) inside the stereo itself. Maybe try and check out if the manual says any thing about the issue, if not im sure your local stereo installers could help you out.
Mar 01, 2011 | Car Audio & Video
Evening My Canon 400D Eos SLR will not take photos in manual mode setting , goes through the motions of shutter open and close but when it comes to viewing the picture on the lcd display ( nothing there)....
Okay lets put some "joy" back into your photo's The reason you aren't getting anything is because your shutter speed is to fast. Your setting I think you are trying to say are F5.6 100 ISO and 1/100 shutter speed "M" manual setting. Actually if you looked closely on your "nothing there" there would be something. Anyway, Moon shots as simple as they look are anything but simple. The earth is moving and you are trying to take a still shot. I don't know where you are on this earth and every star system is different. Starting with a good solid tripod, next the lens needs to have a great enough focal length so the moon covers 2/3rds of the view (first shot) ISO 100 is good. In manual mode look at your light meter try to have your F-stop at F8 or F11 and adjust the shutter speed for proper exposure, you may need to adjust your aperture up or down once you have a "normal" exposure either increase your shutter speed or preferably stop down the lens two stops.
Your camera will meter down to 30 seconds if it goes below this then this is where you take your start (first shot) meter reading and count how many stops of light you require beyond 30 seconds.
For practice though attempt to stay within the 30 seconds by increasing the aperture but not wide open say F8 is as low as you go, need some speed adjust the ISO up to ISO 200 then ISO 400 don't go beyond this because other factors come into play at this point. the thing is you need to establish a metering point then stop down two stops and see what you have as far as exposure.
I know this may all sound really complicated but it's not the most important thing is to have a good tripod use F8 as your widest aperture don't increase beyond ISO 400 and keep your shutter speed at 30 second or above. Another problem that will occur is focus actually the lack of, your camera requires contrast to focus one you have established this shift the lens into manual and recompose your scene. What we aren't done yet don't touch the camera when your release the shutter. Use the 2 second time delay to give the camera time to stop vibrating after the shutter has bee depressed remove your hand DON'T touch it until the picture is finished. If it were me I'd be looking at doing a few landscapes at night to get use to all this stuff then tackle the moon so to speak. In the mean time here is a picture of The Fork Of the Thames in London Ontario Canada.
Picture here
Jan 14, 2011 | Canon EOS 450D Digital Camera
Nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting). Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
Apr 16, 2010 | Nikon F3HP 35mm SLR Camera
Changed my factory stereo with an after market stereo and now truck wont start what do i need to do or what didnt i di its a 1998 ford ranger xlt
put back the factory stereo if the car works then you have a model that depends on that head unite you will need to use a factory stereo by pass harness to solve this problem when you install you after market unite.this is a common issue with newer factory stereo's if putting back your factory stereo does not fix this then check all your fuse's generly there are more then one fuse box in newer cars
Mar 18, 2010 | Car Audio & Video
Exposure meter of Ricoh SLR camera ''KR-10X'' not working
No 35mm camera can be converted to digital. The other issues are purely down to the age of the equipment - replace it with a modern DSLR
Jul 16, 2017 | Photography
Install after market stereo in 2002 malibu ls security shutdowns
yes you have to get a GM pass lock harness the security, door chime, and a few other systems are run through the radio. the harness you need cost about $120 at your local car audio store.
Dec 29, 2008 | 2002 Chevrolet Malibu
Stereo wont work
It sounds like a wire somewhere in the wires that run to the speakers is getting a short. Something very similar happened on my mothers car. I trouble shot it and eventually found out it was the stereo that needed replacing.
You can buy a new stereo anywhere that sells them. Be cautious of used as you never really know what you are getting. Installing a new stereo is not very difficult but you have to make sure you have everything you need. You can get everything you need at your local electronics store. Just go to the mobil audio section and tell them which stereo you want and that you need the stuff to install it. All the places around where I live have free instalation with the purchase of a new stereo. Most after market stereos will require a dash kit to fill in the space left over from the size difference between the factory stereo and the after market stereo.
Nov 13, 2008 | 2004 Honda Accord
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
