Question about HP Office Equipment & Supplies
Error 20.10 hp plus - HP Office Equipment & Supplies
check with HP printer information by model #.
Jul 31, 2014 | HP DesignJet 750c plus InkJet Printer
6500a plus non hp cartridge over ride does not work
For print cartridge errors you may try following the article: Print Cartridge Errors. However, since they are refilled ink cartridges HP cannot guarantee that they will work correctly.
Can I Refill The Ink In My HP Ink Cartridge?
Don't forgot to say thanks by giving "Kudos" to those that help solve your problems.
Read More Help... HP Printer Support
Jul 24, 2014 | HEWLETT-PACKARD 6500A Plus InkJet Printer
HP Laser Jet 4 Plus error code 52 What do I do now?
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Jan 18, 2010 | HP LaserJet 4 plus Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
Hp 750c plus System error 060309
Please take a look at this link and follow the instructions given there. Also relevant links here and here.
Hope that helps you to sort it out!
May 22, 2009 | HP DesignJet 750c plus InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
HP LJ II P plus
The laser PCA is bad.
I removed it and the printer functioned.
I thank you really after all.
Jul 25, 2008 | HP LaserJet IIp plus Printer
Error on display
either bad carriage or trailing cable if you've already tried new inks.
Jan 16, 2008 | HP DesignJet 750c plus InkJet Printer
According to the HP LaserJet 4 plus service guide. Your error code of 57.1 indicates the following;
1) The printer's gears are siezed
2) The DC controller or main motor is defective.
Nov 10, 2007 | HP LaserJet 4 plus Printer
26 people viewed this question
Ben Johnson
