Question about The Computers & Internet
I have signed up for P.I.A vpn and was wondering how I set it up on my router so all devices can use the vpn
  • The Master
  • 2,028 Answers
Try the link to explain what to do Where to Find Your Model Number
Some better routers are unable to be configured for VPN use
Posted on May 11, 2017
5 Suggested Answers
beeveez
  • 167 Answers
SOURCE: VPN tunnel between two DLINK VPN DIR-130
- Logon to the configuration page of your D-Link.
- Go to Advanced tab
- And Click on Firewall Settings on the left side
- Under that look for Application Gateway Level at the bottom and you must uncheck at the box on it and click on save settings at the top.
Posted on Mar 08, 2009
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
CodeGuru
  • 95 Answers
SOURCE: VPN misconfigured after belkin router was configured XP
Hi Grahmmy..
I am myself a (cisco certified network associate)CCNA, we have configured several VPNs on XP, please try these steps and im sure you'll be able to reconfigure the Virtual private network on your XP...
  1. First open the control panel by clicking start,open the Network Connections item in Control Panel. A list of existing dial-up and LAN connections will appear.
  2. Choose the 'Create a new connection' item from the left-hand side of the window. The Windows XP New Connection Wizard will appear on the screen.
  3. First click Next to begin the wizard, then choose the 'Connect to the network at my workplace' item from the list and click Next.
  4. On the Network Connection page of the wizard, choose the 'Virtual Private Network connection' option and click Next.
  5. Enter a name for the new VPN connection in the 'Company Name' field and click Next. The name chosen need not match the name of an actual business.
  6. Choose an option on the 'Public Network' screen and click Next. The default option, 'Automatically dial this initial connection' can be used if the VPN connection will always be initiated when the computer is not already connected to the Internet. Otherwise, choose the 'Do not dial the initial connection' option. This option requires that the public Internet connection be established first, before this new VPN connection will be initiated.
  7. Enter the name or IP address of the VPN remote access server to connect to, and click Next. Company network administrators will provide this information.
  8. Choose an option on the "Connection Availability" screen and click Next. The default option, 'My Use Only,' ensures that Windows will make this new connection available only to the currently logged on user. Otherwise, choose the 'Anyone's use' option.
  9. Click Finish to complete the wizard. The new VPN connection information has been saved. Good luck ;-)
Posted on Apr 22, 2010
Testimonial: "it worked for me ;)"
marked
  • 6487 Answers
SOURCE: Every time I try to
Base from the description of your problem this issue has something to do with the firmware of your router, so to correct the problem do a firmware upgrade on your router or if there's no updated firmware you just flash the firmware to it then check if the problem is already fix after doing that.
Posted on Sep 09, 2010
How connect cisco 5015 vpn with barracuda linkbalancer 330
Your Internet gateway <--- primary router
Port #1 on primary router <---> VPN server
Port #2 on primary router <--> Load Balancer
Load Balancer <--> web-server #1
Load Balancer <--> web-server #2
Load Balancer <--> web-server #3
VPN traffic enters your network, through the router to the VPN server, and then VPN-server back through the router to your internal servers. Web-traffic goes through the Load Balancer, for distribution to the collection of servers.
Jun 12, 2014 | WatchGuard Technologies WATCHGUARD TECH...
Jan 12, 2010 | Linksys WRT120N Router
Edimax BR-6574n wifi VPN connection problem
I have reseted the router configuration back to Factory Default, and set it up again from the beginning. I think the problem was at the firewall settings.
Aug 24, 2009 | Edimax PRI-682 Router (PRI682)
Router settings to allow MacPro to access corporate VPN through router
The university that I attend compiled a great guide for setting up their VPN off campus. These should work for you as well:
http://www.it.ubc.ca/security/VPN/setupdocs.html
So far as I can tell, you shouldn't have to change the settings on your router to access a VPN from your home.
Aug 14, 2009 | Linksys RVS4000 Router
Mar 02, 2009 | D-Link (DIR-130) Router
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have netgear wpn824 wireless router and it works fine until I try to connect to my work server through their Sonicwall VPN. If I unplug the netgear and go straight into my computer through the DSL modem...
Two routers on two different sets of internal IP addresses will cause all kinds of conflicts. A VPN router is even worse. VPNs (virtual private networks) are designed to create encrypted tunnels between two computers. The computer its set to connect to must be authorized either as a user or a device with proper credentials. If your VPN authorizes devices based on MAC addresses, then unless your router's MAC address was previously authorized, youre not going to connect. Lets take the router out of the equation for a second. Do you have a working broadband connection from the sonicwall that the router can be plugged into? If you do, then you can treat this connection to your router like its a cable modem or DSL. If this connection has manual settings (such as IP address, default gateway, and primary and secondary DNS addresses) you will need these settings too. Post back and keep us updated...
Jan 17, 2009 | Computers & Internet
Westel 327W no longer accessing VPN
It sounds like your company has changed some settings for access into thier local intranet. Your IT guy will have to figure out what's wrong, becuase he would be the one with the knowledge of your companies settings. Perhaps they changed the shared-key, or something in the security settings.
Another note: If you have recently changed/upgraded any installations of firewalls or internet security software, check to make sure it's not blocking any of the IP address or ports you need open to access your company network.
Mar 28, 2008 | Westell Wirespeed VersaLink...
Computers & Internet Logo
Top The Computers & Internet Experts
tim brauer
tim brauer
Dilum Senarath
Dilum Senarath
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
