Question about PRINTER Office Equipment & Supplies
My colour printer 7328 error 009-390 - PRINTER Office Equipment & Supplies
009-349 key to reset
There's no reset for that error, the error indicates that the 1st BTR did not reach the retract position. Try clean the 1st BTR Retract Sensor and look for damage. Also check the gears for breakage.
Jul 28, 2015 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7328 touch screen not taken
I share a links, so read it and follow instructions. If not understand then contact printer support technician and check it why your printer touch screen not working.
Read more..http://www.office.xerox.com/latest/W73EG-01U.pdfand Xerox Printer Support
Thanks,
Sep 05, 2014 | Xerox WorkCentre 7328 Multifunction laser...
Error code - 001-302
check if the front cover is closed properly. If this doesn't work try rebooting the printer with the front cover open. Close it when it started up. Clean sensors. All not working. Engineer.
Nov 27, 2013 | Xerox WorkCentre 7328 Colour Multifunction...
Xerox 7328 not printing in color
Ensure that you are intalling the correct print driver, www.xerox.com, support section.
Also check to make sure that the colour option in the printing preference is not set to Black and white or grayscale.
Also ensure that you dont have any accounting option set to black and white only.
Dec 28, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Fault code 008-164 for xerox workcentre 7328
Xerox 7346
What is the problem of error code 008-164
Nov 07, 2012 | Xerox WorkCentre 7328 Multifunction laser...
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
Jun 23, 2012 | Xerox Workcentre 5225 / Copier, With...
XEROX WORKCENTRE 7328 IS RUNNING SLOW WHILE PRINTING PDFs
Are you printing to the printer using the Xerox Global Print Driver PCL6? If so, this will be the cause of your problem. Earlier versions of the driver werent as bad when processing PDF documents. I would suggest that you download the Workcentre 7328 PCL6 driver and try that - the problem should clear.
Cheers
Jon.
Dec 17, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Our xerox workcentre 7328 shows fault code 004-346
I don't have that manual, but similar manuals say IBT Home Sensor Error. Check your accumulator belt for damage. You may also have a dirty sensor.
The belt PN is 604K20891and is rather expensive and fragile
Whit
Item, Inc.
Aug 06, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Top PRINTER Office Equipment & Supplies Experts
murray greenberger
Level 1 Expert
John Hong
John Hong
rfredey
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
