Question about Microwave Ovens
THE PLATE HAS STOPPED ROTATING THE OVEN COMES OIN AND HEATES UP BUT THE PLATE DOES NOT ROTATE
  • Microwave Ovens Master
  • 4,393 Answers
The small motor that turns the plate has failed. it needs to be replaced
Posted on May 11, 2017
The glass plate of the oven is not rotating, what should I do.is it safe to run the oven like this.
The motor driving the turntable is faulty, using the oven like this will not damage the oven, the food will not be cooked evenly though. Open the door and rotate the food occasionally to ensure allround cooking, close door and continue cooking.
Sep 29, 2014 | LG Microwave Ovens
Turntable stopped rotating
Sure, if parts are available.
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
In some brands, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find links to helpful exploded view diagrams and part ordering help here.
Apr 22, 2013 | Microwave Ovens
The plate is not rotating
problem is likely the motor or gear drive it runs
Nov 06, 2012 | LG Microwave Ovens
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
Plate does not rotate freely and make noice
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2008 | Sharp R-1480 Microwave Oven
Plate won/t rotate no reheating
PLease open the housing of turn table motor at bottom of the oven and check for the AC input voltages on motor terminals as specified on sticker on motor. for no heating please check fuse between high voltage transformer and high voltage capacitor. Also check high voltage Diode and Magnetron.Please please don't try to measure voltage on terminals of magnetron.
Jul 29, 2007 | Whirlpool MH6141XK Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
