Question about Xerox Office Equipment & Supplies
Hi Xerox Phaser 7800 failing to boot. How can this be resolved.
SOURCE: Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Posted on Jun 06, 2008
SOURCE: XEROX PHASER 3500. 8220 FUSER
LE HE CAMBIADOS DOS VECES EL FUSOR A LA IMPRESORA XEROX 3500, SE HA DAñADO SUPUESTAMENTE POR CAUSA DE LA ELECTRICIDAD, USTEDES ME RECOMENDARIAN USAR OTRA O SABER SI EL FUSOR REALMENTE HA SIDO REPARADO Y POR ESA RAZON VUELVE A DAñARSE.-
Posted on Dec 07, 2008
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 110 Answers
SOURCE: hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Posted on Oct 29, 2009
  • 53 Answers
SOURCE: xerox phaser 3450 has power but won't boot up
it could be the hard drive that is messed up. hard drives here in SA cost about 700 bucks brand new IDE
Posted on Nov 20, 2009
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Engine failure
Hi Zelwe Mwanza
show me error code pls
Dec 27, 2013 | Xerox Printer Division Xerox Phaser...
How to fix problems with electric contact of a xerox phaser 7800dn
Go to the Xerox website and read up on your model. Also see if there is a fuse blown between the power cord and the system itself. Maybe the transformer has died. and needs to be replaced. That happens a lot with devices with 'step down' transformers combined with the electric cord as opposed to transformers built into the device.
May 31, 2013 | Xerox 7800/DN - Phaser 7800dn; 12 X 18...
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Sep 11, 2012 | Xerox Phaser 7800GX LED Printer - Color -...
Error xerox Phaser 8200 15004,45:12318
Hi erniec420:
Hope that this helps.
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Apr 03, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8500N front control panel LCD died
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1866-877-0191 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Nov 26, 2007 | Tektronix Phaser 860DP Thermal Printer
70 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
