Question about IFB Washing Machines
Pcb board has to be changed to make ifb elena frontloading washing machin to spin dry. Is it necessary
kjmac
  • 97 Answers
SOURCE: Faulty washing machine w123
does the water empty from the machine? if not you will more than likely have something trapped in the pump. the best thing to do is run the grey outlet hose into a bucket, this will empty the machine. then tilt machine back (make sure it wont fall) then remove the plastic kick plate on the front bottom, behind this you should see the round plastic filter this will unscrew and pull out, you may need a couple of towels put on the floor as there is usually water left in the pipes. clean any debris and screw filter back in, should only need to be hand tight. replace kick plate and then give it try.
hope this helps
kj
REMEMBER MAKE SURE POWER IS OFF BEFORE CARRYING OUT ANY WORK.
Posted on Nov 12, 2007
barkencoa
  • 3463 Answers
SOURCE: I NEED PCB BOARD FOR
I have checked the Hotpoint web site, and a pcb is £114.00.
You also need the eprom which plugs into the pcb,this is another £24.00, and is unprogrammed, this means that it is a blank memory chip, and has to have the programmes put into memory.
This is something that only Hotpoint can do, so you have to add the cost of calling an enginner to the cost of the parts.
This as you can see, makes it very expensive to repair.
It would be in excess of £200.00.
There is one other alternative, and that is, if the washer is less than 5 years old, then you should be covered by the Hotpoint 5 year part guarantee, but you would have to confirm this with Hotpoint.
It would certainley be cheaper to do it this way.
Plz rate my solution.
Thanks,
Posted on Jan 12, 2009
  • 38 Answers
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Posted on Mar 08, 2009
SOURCE: frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Posted on Mar 24, 2009
SOURCE: IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Posted on Jul 25, 2009
I have IFB washing machine it shows E7 error
1:IFB Washing Machine Not Turning ON OR Turns ON But Does not Starts. 2:IFB Washing Machine Door Does Not Opening. DE Error 3: Water is not coming inside the IFB Washing Machine Inlet problem 4:Water is Leaking from the washing machine, drum or hose pipe damaged 5:Wash is not happening / Spin not Happening in the IFB Washing Machine 6:Drum NOt rotating or Drum Making Huge Sound while spin cycle, 7:Water not Draining From the washing Machine 8:Burning smell, Tripping Problem, etc https://electronicshelponline.blogspot.com/
Read more: http://ifbservices-com.webnode.in/error-code-fault-codes/
Aug 05, 2016 | IFB Washing Machines
I have ifb wasing machine which shows error code as E 6 where coin trap is free
if U R in india call 18604255678 or search for customer care # & call them
Jul 30, 2014 | IFB Washing Machines
Burning smell along with fumes came out after a ghastly spin of the drier. after that it can't be switched on. Mine is a front loading washing machine (IFB executive plus).
Don't try to turn on again. Call a service agent for that brand of machine and leave it to them. Obviously a major problem and could cause major damage to your home if you force it on again
Jan 14, 2013 | IFB Washing Machines
Ifb front pcb diagram
What is the model number of your unit?
Nov 01, 2012 | IFB Washing Machines
I have ifb elenaa washing machine. my problem is that water can't enter or drain from machine .help
make sure the water is turned on at the faucet handle behind the washer.
Apr 20, 2012 | IFB ELENA
IFB ELENA SERVICE MANUAL
water not coming in soap tray.
Apr 17, 2012 | IFB ELENA
Washing machine IFB,senorita model, PCB cost
Any one who buys IFB washing machine is made as fool both by the Company and by the Service Centers.
.. an idiotic owner of SENORITA DX, fully automatic from Pondicherry.
Aug 04, 2010 | Washing Machines
Mar 24, 2008 | Maytag Performa PAV2200
Washing Machines Logo
Top IFB Washing Machines Experts
Eric Taylor
Eric Sutherland
Ken Strite
Ken Strite
Are you an IFB Washing Machine Expert? Answer questions, earn points and help others
