Question about The Computers & Internet
Spider Bit: Can you get additional bit looking sites around the same area of the original bit, a few weeks after?
4 Suggested Answers
  • 82 Answers
SOURCE: sound
Friend there are two possible problem and two possible solution in your computer.
First problem is that the volume control of your computer is lowered that you can't hear any sound. The solution is to find the possible volume controls in your computer. If you are using windows OS, Go to the CONTROL PANEL in your computer and double click Sounds and Audio Devices then check the level of your volume, also check if they are muted.
Here's how you do it:
Click START then point the arrow to settings click CONTROL PANEL then double click Sounds and Audio Device.
The next possible problem about your computer is when it is infected with virus. Having a computer infected with virus will affect some or in worst case all the functions of your computer.
The possible solution to this problem is to Reinstall the driver for your cam, but before you do that you must clean your computer with an updated antivirus program. reinstalling cam drivers is easy, just read carefully and follow the instruction prompted by the screen on your computer. In the case of the antivirus program you can download it through the internet.
P.S. if it helps you please don't forget to rate me.
Posted on Jul 16, 2008
  • 173 Answers
SOURCE: i can't find java windows
Posted on Mar 15, 2011
  • 76 Answers
SOURCE: c++ not working in Windows7 64 bit
codeblocks is a easy to setup compiler you would like if your beginning and its helps alot. Just download the 64 bit version of the compiler from their site and your good to go.
Posted on Oct 05, 2012
Tiny soft-bodied, bright orange bug bit me. What might it be?
I wonder if it was a red spider mite, but there are hundreds of possibilities.
Red Spider Mite
Here are a few more. Look at the images tab as well.
tiny soft bodied bright orange bug Google Search
Mar 28, 2017 | Orange Computers & Internet
Might be from a false black widow, clean it with soap and water really good, helps to suck out poison and pus with a vaccum for 2 seconds, antibiotic cream after cleaning, Vaseline will help keep crud out if you don't have antibiotic cream. keep elevated if it swells up, see a doctor if it gets infected or if it grows. Look at Google images results to compare her reaction to other spider bite wounds.
Check Mayo Clinic web advisor for confirmation of this.
Sep 19, 2016 | Cars & Trucks
Need to know symptoms of a black widow spider bite
Hello Christy, normaly I don't answer medical questions here this is a auto repair forum ,with that said I reacently got bit by a barn spider 1 week passed and nothing then started to get flu like symptoms pain in my arm sweating ,cramping, the same for black widow spider bite , DON'T SCREW AROUND GO TO A DOCTOR OR ER. the results I had a brain swell from a 104 deg temp for 3 days I have lost most of my vision in my right eye from it . im better now but no return of vision doc said it may take a year or maybe NEVER. good luck please seek medical attention .
Oct 01, 2014 | Home
The chain has snapped and hit the left side crank case and put a hole in it about the size of a 10p. Do you think I could cover this with something and if so can you reccomend anything as the cost of a new...
If you're sure the piece that got punched out is gone and not inside the engine waiting to ruin your day even further then you could in theory get by with good old jb weld.
Remove the cover and totally degrease the thing inside and out. While it's off look for any bits loose inside the cover. Find yourself a bit of steel mesh (window screen) big enough to cover the hole plus a bit. Put the screen over the hole and use a sharpy to mark it's edges. remove the screen and take a drill with a small bit ( < 1/8"). Pop a few holes in the area of coverage of the screen and around the hole. These holes give the jb weld more grip as it will flow into the holes and harden. The holes need not go thru but if a few do its good.
Take a small file and roughen the surface around the hole so the jb weld will have something to grab onto. degrease the area smear some jb around the hole from the outside and set your screen into the jb weld....add some more jb over the screen. Use a wet finger to smooth out the jb weld (if you add over this then don't forget to clean and roughen again).
Look inside the cover and smooth out any jb that came thru to the inside. Of course you have roughened inside the case so any jb inside will adhere nicely.
Once the jb has fully set you should be good to go....monitor your repair for any leaking. Also look closely for any cracks radiating away from the hole and make sure your repair covers them as well.
Take care.
Dec 08, 2010 | 2000 kawasaki KMX 125
C++ not working in Windows7 64 bit
rty geeting the c++ supprted for windows 64 bit,,,,,u can get it in
Jul 07, 2010 | Microsoft Windows Vista Ultimate Edition
I have a ge washer model whdsr316g1ww. the belt seems too small cannot get it around pully. ge said i have the right belt.please help!!
Have you loosened the motor mounts to help swing the motor closer to the pulley? If you have is something blocking the motor moving further?
Some belts can be a bit tight to get on so hook it up on the motor pulley first and then get one side on to the main spider pulley and then turn the main spider pulley to thread the belt on. Providing the belt was in its original grooves on the motor pulley as you turn the spider to get the belt on it will cetre itself. Then tension the belt by pulling on the motor and tighten the bolts. DON'T OVER TENSION THE BELT AS IT CAN SNAP IT OR THE SPIDER PULLEY!
Feb 25, 2010 | Washing Machines
Tv not letting remote work. Have 2 remotes it is the TV. Philips
what you have is a bad IR sensor board. The part # is:
313926859182. Right now, there are so many of these things failing, that finding the original might be difficult.
Don't fear, though; it's a small part. And, best of all, it's cheap. Expect to pay around $5.00 for the part, maybe a bit more, maybe less, depending on the supplier.
Now, if you are handy with a power drill (fitted with an octagon/star bit for the back of your set), you can remove the 20 or so star-bit screws from the back of your television. Don't worry about putting the set on the floor. If your TV is on a stand, simply turn it around. You'll need to remove the stand screws, but you won't need to take the TV off of the stand.
Now that you've taken the screws out and removed the back cover, look in the lower left hand area of your set. You'll see a 4 inch long circuit board with 2 cables running to it. Pull the cables out (they'll come out easy). Remove the 2 star-bit screws.
One of the board's sides is under a plastic tab. Lift the board out of its slot from the other side.
Put your new board in, reconnect the two cables, reassemble the back and you are set to go.
Expensive repair for a few bucks and a better IR sensor.
Mar 23, 2009 | Philips 42PFL5332D 42 in. LCD Television
Sorry, no, you cannot 'convert' the 64 bit system to the 32 bit one. You
have a few options. All of them are coloured by the fact that the OEM
license gives you the right to use just the version you originally
1. Remove the 64 bit version and install the 32 bit. To do this, you
might be able to arrange with the original source to get the 32 bit OEM
version. Alternate, purchase the 32 bit license of the retail version.
If the 64 bit version runs correctly (all the devices/peripherals work
correctly) and the issue is program compatibility:
2. Install the 32 bit in a dual boot arrangement. A Google search will
yield links to various sites with the instructions for doing that. Do
note that you should get the method for installing the 32 bit after the
64 bit
Since you have an OEM version, your first point of contact would be
whoever you got it.
Jan 05, 2009 | Microsoft Windows XP Professional for PC
Difference between 16 & 12 bit analog signal
In audio 12 bit selection, you can add audio (audio dub) without deleting or damaging original sound track. Like narrating some introduction in your voice and keeping background / original sound as well. 4 bit difference is used to add additional sound in same sound file without deleting previous audio data.
16 bit audio selection will not give you this option and audio-dub option will be disabled. If you want to add more audio, you have to over write complete sound track in movie file.
I'm not sure that I conveyed it to you correctly. Need further info, let me know.
Dec 18, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
