How to find #
Witch keys to touch to add #
    Habit-Forming:
  • 129 Answers
Press shift and the number three simultaneously on your keyboard.
Posted on May 11, 2017
How do I enter contacts and their phone numbers
Hi Joseph
Add a New Contact
Step 1 Touch the "Main Menu" soft key on your LG phone, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option to access a menu that allows you to add a new contact. Select the "New Contact" option using the soft key or directional keys. This action opens a blank contact template.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Add the contact name in the same manner. Touch or select "Save" to complete the addition of the new contact.
Add a New Number to an Existing Contact
Step 1 Touch the "Main Menu" soft key, or use the directional keys on your phone to select the "Main Menu" option.
Step 2 Touch or select the "Contacts" option. Scroll through your contact list and select an existing contact to whom you want to add a number. Touch or select the "Edit" option.
Step 3 Touch or select one of the blank number fields, such as Mobile 1 or Work. Use the keypad to enter the appropriate number into the field. Edit the contact name in the same manner if desired. Touch or select "Save" to save the new number under the existing contact.
Apr 18, 2016 | LG Cell Phones
After replacing headlight bulb on 06 tl key won't start
The battery pole are loose or they are very stiff I'm not shure witch side is the battery on your car but that can be the cause... and when you said won't start what do you meands ... no sound at all?
Jan 10, 2014 | Magnum Remusshield Finger Touch...
How to replace ignition key battery
remove mettle key blade from you key, for remove key blade you have to slide lock witch is sitting in top of your key, near the mettle key you can see small sliding switch, remove mettle key, then have a look not in the deep hole witch is mettle key was insert but left of the mettle key remove sliding switch small grow witch is mettle key head ware sitting in, if you have a good look small gray sliding part is there, you have to use mettle key blade to press it and press it backward of key when you press it you can see it's moving, keep that moving part press by mettle key and pull out the key head, then you can see battery in that part witch is came out from key before remove the battery keep in mind negative and positive it have mention on battery replace battery and jest push key head in to the key til lock insert the right way , is this information helped you? please leave a comment.
Oct 16, 2010 | 2000 Mercedes-Benz S-Class
Witch line do i add refrigerent
The thicker line is the low pressure one.
Jun 29, 2010 | 1993 GMC Sierra K1500
How do I unlock my router?? I want to add my ipod touch to my internet
If you have already setup your WEP key you would need to add that WEP key into you IPOD Touch settings.
Open up your IPOD Touch and click your Settings button. Touch your Wi-Fi option and turn on your Wi-Fi. Under Choose a Network you should see your SSID. When it ask you to put in your WEP Key just enter you key.
If you have not setup your WEP Key you need to open up a broswer and type in the following:
http://192.168.1.1
A screen will pop up requesting your user name and password. If you have changed your password place that in. If you have not changed the password then use the default admin. Leave the username blank.
Click on the Wireless Tab. Click on the sub tab Wireless Security. Set your WEP Key.
Hope that helps you!
Dec 31, 2009 | Linksys WRT160N Wireless Router
Canon IR 3100 CN needs pasword
you need to clear thepassword in this order touch ADD FUNC key then the 2 and 8 keys together then touch ADD FUNC key again lcd screen should change touch copier then function then clear then pwd then ok then yellow reset 3 times that should do it
Aug 24, 2009 | Canon imageRUNNER C3200 Copier
I recently purchased an acer laptop w/o the owners manual. i really happy so far... would you please tell me what key i am touching that makes the screen go smaller and smaller or bigger and bigger. Thank...
Could you Plz Spesify the model of the laptop? would just make it easier for the problems solf team to help you more with an exact answer on witch keys to use
Regards SlitWrists
Apr 23, 2009 | Computers & Internet
I need source code of trial version to add to a software product
witch trail version witch program
ben.pluijm@viveole.com
Apr 14, 2009 | Computers & Internet
Waste toner
right hand side lower right bottom cover 2 scrrews remove cover bottle behind it . then you need to clear counter in service mode in this order touch add func key then 2 & 8 at same time then add func key again screen should change to serv mode then in this order touch copier / counter/ misc/ waste toner/ clear key/ ok turn off then on
Jan 19, 2009 | Canon imageRUNNER C6800 Copier
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
