Can someone help me know where i can purchase maintenance kit for laser-jet 600m 602m, fuser roller and transfer
  • 2072 Answers
SOURCE: Still having paper feeding issue
Yeah it should make contact with the drum, but it moved up and down to make and break contact with a clutch.
What I strongly suspect is that you have a bad registration clutch. That drives the rollers just out of the paper tray and is very prone to failure.
If you want to try and replace that let me know, I can get you the part number to order and tell you how to replace it. It really is not hard to do at all.
Just removal of the left side cover and a couple of clips.
Posted on Jan 13, 2009
POCBM
  • 121 Answers
SOURCE: need to change out a fuser kit
1. Turn the printer off.
2. Open the top cover.
3. Grasp the purple handles on the fuser.
4. Remove the old fuser from the printer.
5. Install the new fuser.
6. Close the top cover.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c00366229/c00366229.pdf
Posted on Mar 20, 2009
  • 32 Answers
SOURCE: Need to reset the counter
First, you enter the config menu by powering off the printer. Hold the middle and right arrow buttons and turn the printer back one. Continue to hold until you see Performing self test. Then release. You will then see config menu. Scroll down to reset maintenance count and press select. It will reset and bring you back. Then restart the printer.
Posted on Jul 24, 2009
  • 3 Answers
SOURCE: WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE
The fuser assembly is part of the HP Maintenance Kit. The HP part number is Q5421A. Be sure to use the one for the 4250. The 4200 and 4250 are so very similar but the maintenance kits/fusers are differnet. The 4200 is less expensive but can not be used. It fits but causes other issues.
Posted on Dec 23, 2009
Daniel S
  • 4323 Answers
SOURCE: I have an HP 4700
Hi
This issue arises due to hardware malfunction, software issue or drivers. I hope you're using the original HP Cartridges and paper that meets the HP paper specifications. First of all uninstall and reinstall the printer drivers, clean the print head and printing path with a lint free cloth. Use another new cartridge. If still the issue is not resolved then it means that it is a hardware issue. However, I'll recommend you to see the link for detailed information before going further. In case the issue is not resolved, I suggest you to buy a new printer. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 25, 2011
50.2 fuser fault on a HP laser jet 4350dtn
Indicates that fuser is not cycling properly. Usually caused by a failed fuser. If your page count is anywhere near 200,000 pages, your best bet is to purchase a maintenance kit which will come with a new fuser, as well as the feed/separation rollers.
May 27, 2011 | HP LaserJet 4350dtn Printer
80 scheduled maintenance will not print
There is a maintenance kit you need to get and install. Then you'll have to go into maintenance mode and reset the maintenance count. I don't remember the button sequence, but if there is a printere repair shop in your city, most likely one of their techs will tell you how to reset the count. But you really should install the kit first. It consists of feed rollers, charge and transfer rollers, and fuser. It's not difficult to install and the kit can be purchased with a refurbished fuser from many vendors at reasonable prices.
Mar 05, 2011 | Lexmark Optra T614 Laser Printer
It keeps saying replace maintence kit. I don't even know what that is. Can you please help
Maintenance Kit - Contains: Fuser, Transfer Roller, Paper Feed Rollers & Separation Pads , etc
look at below picture, kit available with instruction manual etc its easy to replace. or you can give it to the service center.
best of luck
Jan 26, 2011 | Ricoh Aficio AP610N Laser Printer
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
Jan 19, 2011 | HP LaserJet 4350 Printer
Laser Jet P2015dn only prints in grey not black. Changed the toner cartridge - didn't help. Went into properties menu, looked to see if "econo" mode is on, and that doesn't exist. Help!
Sounds like you might have a transfer roller that needs to be replaced. The transfer roller is under where the cartridge seats and transfers the toner to the paper...If toner is not sticking to the transfer roller it will show what you are seeing....Transfer rollers come in Maintenance kits. If the transfer roller is not the issue....its most definitely the fuser not fusing the toner completely, due to improper heating, to the page giving a lightness.
Oct 19, 2010 | HP LaserJet P2015dn Printer
I am getting 3 dots just right of center. I have
This can only be caused by one of 3 things. The fuser, the transfer roller or the toner cartridge. If you installed a maintenance kit, you replaced the fuser and transfer roller. So, it has to be your toner cartridge. If a new cartridge doesn't solve this, you get into the laser and formatter circuitry. Based on the age of the printer, this would not be economically repairable.
Nov 10, 2009 | HP LaserJet 4 plus Printer
Lite toner marks on paper
The imaging drum is included in the toner cartridge on this one, so you could need a new toner cartridge. If that doesn't fix it, then you are looking at either the transfer roller or the fuser needs replaced. Workgroup printers usually require a maintenance kit after 300,000 pages printed, fyi. that kit includes feed rollers, a fuser, and a transfer roller. Not sure what the page count is, but that could help you figure it out.
Nov 03, 2009 | Lexmark T644 Laser Printer
WHERE'S THE FUSER ROLLER AND WHERE DO YOU PURCHASE FUSER OIL ON A HP LASER JET 4250 N PRINTER?
The 4250 uses an "assembly" that does not use fuser oil. The fuser is housed in the rear of the printer. It applies heat and pressure to the paper as it exits, melting the toner into the fibers of the paper. Some fusers are remanufactured. If done properly, with the proper amount of fuser sleeve grease, these fusers can last as long as the original equipment fuser.
If not properly trained, fusers should not be disassembled and rebuilt.
Oct 01, 2009 | HP LaserJet 4250n Printer
Printer is ghosting - I have changed power supply
Might be your transfer roller. I would try some laser cleaning paper and run that through a few times. If that doesn't work, I would purchase a fuser maintenance kit which will have the rollers as well as a new fuser.
Dec 15, 2008 | Brother HL-2040 Laser Printer
Replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Jan 17, 2008 | Ricoh Aficio AP600N Laser Printer
27 people viewed this question
k24674
jasbo
jasbo
