Question about Car Audio & Video
Wattage and wiring diagram for performance technique icbm-epx
  • 631 Answers
SOURCE: performance teknique icbm-896 stick on diagnostics
If it's in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Sep 11, 2008
  • 37 Answers
SOURCE: I need to know if
The 500W RMS total wattage is for both coils combined. If you want to get REALLY specific, all of the industry-specific specifications are as follows.
  • 12" Dual 4 Ohm Peformance Subwoofer
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Impedance: Dual 4 ohm
  • Reinforced aluminum curvilinear cone woofer
  • Oversized butyl rubber surround
  • 5 spoke Die-cast aluminum basket
  • 2" Flat ultra excursion spider
  • Industrial Chromed Hex bolt retained T-Yoke
  • DC resistance (Re): 3.2 ohms each coil
  • Frequency range: 20 Hz-1.1 kHz
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • SPL: 89.58 dB 1W/1m
  • Xmax:16mm
  • Mounting Depth: 160 MM
  • Mounting Hole Dia.:282 MM
  • Posted on Mar 01, 2011
    • 33 Answers
    SOURCE: i have a Performance Teknique
    The alarm shouldn't require any programming to function.
    Posted on Apr 13, 2011
    Ironfist109
    • 3018 Answers
    SOURCE: How would u bridge 2
    • Hi, I can help.
    • As I look at the manufacturer specs and recommendations this amp is not brigable. I figure I would tell you so you did not ruin it.
    • When you bridge you turn 2 channels into 1 channel. This is already a 1 channel amp. Bridging would ruin that amp quick.
    • If you have any comments please feel free to leave them here.
    • Hope this helps and thank you for using FixYa.
    Regards, Tony
    Posted on Aug 27, 2011
    SOURCE: need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
    I have the same sub on the "digital" amp from the same company.
    I used the 1.75 ported box from my jl 12w3v3-4 and it sounds great. I am not sure on the correct box size but the box for the 12w3 sounds great. I tried emailing performance and the email was wrong.
    Posted on Jun 12, 2012
    Performance technique icbm-799 I'm looking for wire diagram OR INSTALL MANUAL N USER GIDE
    The manufacturers do not release the diagrams for this type of device except for repair facilities, sorry that is just how it is.
    Apr 04, 2017 | Car Audio & Video
    Installation-wiring
    Performance Teknique might be able to supply a manual and/or wiring instructions.
    Jan 01, 2014 | Performance Teknique Icbm-7348 Cd Mp3 Wma...
    Need box dimensions for 12 inch performance technique icbm-5912 car subwoofer
    Feb 26, 2012 | Performance Teknique ICBM-5912 Car...
    How would u bridge 2 fosgate punch hx2 to this technique ICBM 9550 2600watts
    • Hi, I can help.
    Regards, Tony
    Aug 27, 2011 | Performance Teknique ICBM-9550 Car Audio...
    I need to know if the specifications for the Perfomance Teknique ICBM-5712DX RMS total wattage is for both coils or per coil. The RMS total wattage rating is 500 watt
  • Power Handling:
    • Peak: 1000 watts
    • RMS: 500 watts
  • Fs:30 Hz
  • QTS:.526
  • QES:.614
  • QMS:7.698
  • VAS:56L
  • SD:.0491M
  • Xmax:16mm
  • Mar 01, 2011 | Performance Teknique ICBM-5712DX 12in Car...
    Lost the manual to program performance teknique icbm-7071 alarm systemHELP!!!!
    there should be a help line number on the product or the box or a website go to the m they can walk u thru it or google instructions for performance technique car alarm
    Feb 24, 2010 | 2-Way Car Alarm System w/ Remote Start
    Hey I just recently buy a performance teknique
    good luck finding one, check ebay, or call Teknique directly.
    Feb 13, 2010 | Performance Teknique ICBM-9794 Car Video...
    I lost user manual for Performance Teknique ICBM-9493TV Car Video
    Yo I have a icbm 5254 in dash monitor and in order to bypass the parking brake security, splice the wire that's marked "park brake"(mine is Pink, yours may be Orange,but it'll be the oddball colors) into the acc or aux wire(usually yellow) and it'll play dvd while moving. Hope this has been helpful.
    Feb 28, 2009 | Performance Teknique ICBM-9493TV Car Video...
    Not enough power delivered
    This sounds like a gain setting problem on your amp. The best way to adjust is to set your volume on the head unit to about 75% volume and then adjust the gain up until it sounds distorted a little. Back it off jst enough for the distortion to go away and you are set. Only other thing to try is use a multimeter set on Ohms to test the resistance of your speaker configuration. Looks like 2000 is th peak power (not RMS) and is only possible at high current configurations. You are probably running at 4 Ohms, but this amp only puts out rated power at 1 ohm stereo or 2 ohm bridged. Many people say Performance Technique are overrated, so maybe not even what it is rated at - 350 x 2 @ 2 ohms bridged (probably only about 175 x 2 at 4 ohms bridged)
    Feb 06, 2008 | Performance Teknique ICBM-9540 Car Audio...
    Car Audio & Video Logo
    49 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
