Can not find pin hole on 3 disc player thomas pacconi model 805
SOURCE: Conia M580 DVD player has
Easy... follow these instructions
  • unplug from the mains
  • take the cover off (3 screws on back panel, 1 screw each side, sticker on top front)
  • You will see the DVD disk in the player drive
  • Remove the plastic ******** top of the drive - 2 x small phillips screws
  • Lift out the DVD disk.... done.
Posted on Nov 30, 2008
Testimonial: "Many many thanks for your help - your instructions were dead-easy to follow and I've now successfully rescued my much-prized "Black Books" DVD disc!!!"
mighty thor
  • 51 Answers
SOURCE: Speed problem on Thomas Pacconi Turntable
probably need the rollers rebuilt
check out needledoctor.com
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: Thomas Pacconi Model TPC-MSE-800 turntable
Pjam,
Had the same problem & checked around on the net. Several people tried replacing the belt, but it had no effect. Spoke w/ several repair shops around the country and they concur with what I'd read on the net - bad motors. 3 or 4 repair/supply shops told me getting a motor would be impossible. Since I only listen to 33-1/3 LP's, I messed around w/ it a little and found a solution. Take the turntable out of the unit & you will find a small circuit board attached to the bottom. On that board is a small square blue fixture w/ a white circular "dial" in the middle (has grooves to accept a small straight blade or a phillips screw driver). This controls the voltage to the motor, which in turn controls the motor RPM's. If you set the selector switch to 78, you can experiment /w turning that white circular "dial" to slow the motor down. It isn't very hard to get the speed set properly. The down side is that you will only be able to play 33-1/3 LP's, but they are probably the most common anyways. I assume you could do the same to set the speed for a 45, rather than a 33-1/3. Down side is that you will only be able to play 1 size LP on the 78 speed setting, but it's an easy adjustment that can keep an otherwise in-op turntable functioning. Good luck!
Posted on Jan 21, 2011
  • 3 Answers
SOURCE: I have Thomas Pacconi turntable which is about 5
penni006
SOURCE: We have a Thomas Pacconi record player and the
TBirdMM, thanks for the advice. I was turning that dial this morning tweaking the rpms and it worked! Strangely enough I actually broke the white dial off, but when I spun a 33 on the 78 setting it played right on! Thanks!
Does anyone know why that dial only effects the 78rpm setting, and if there is a dial for the 33 rpm setting?
Posted on Jul 23, 2012
I need an owners manual for The Thomas Pacconi Classic Model # TPCMSE 805 for my 82 year old father who has lost his and it needs a new phonograph needle and the cassette player is not working.
not sure about a users manual or other parts unit is belt driven
you can by the stylus
turntableneedles com
http://www.turntableneedles.com/THOMAS-PACCONI_c_50123.html
some thing easy diy if no sound while playing a cassette
try cleaning the head (silvery bit )
of the cassette player with cotton bud and metho
Jul 02, 2016 | Audio Players & Recorders
I have Thomas Pacconi 3-speed phonograph model TPC-7475 and wanted to attach external bookshelf speakers. Is there any way to hook speakers up to the line out jacks?
You need to buy the Jack's male plugs, Wal-Mart has them if memory serves, and splice your speaker wires onto them, preferably with a soldering gun and heat shrink insulation.
Jan 12, 2015 | Seth Thomas Pacconi Turntable
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
CD player will not work in my Thomas Pacconi TPC-MSE-800
I have the same unit. Where do you find the screws that hold the cd clamp cover?
May 15, 2012 | Audio Players & Recorders
We have a Thomas Pacconi record player and the band underneither the turntable has stretched out. The band is black, about 1/4" wide, and round. Can you help us.
Jun 09, 2009 | Seth Thomas Pacconi Turntable
Thomas Pacconi turntable turns too slow
My older Thomas Pacconi turntable was also turning too slowly. Rather than replacing the belt or needle, I tried using an eye glass repair screwdriver to alter the trimmers inside the motor. But the changes didn't take. Then I tried trimming the power to the motor using the larger trimpot next to the motor with the motor itself set to the 78 rpm setting. But the adjustments to the trimmer didn't get the platter to spin slow enough - it wouldn't play an LP. To get the speed down further I replaced the 1K trimmer with a 10K trimmer I picked up for a buck at Radio Shack and successfully adjusted the turntable down to down to 33 1/3 rpm usage. All that was needed was a soldering iron and a 10K trimpot to get the job done.
Dec 28, 2008 | Seth Thomas Pacconi Turntable
Dec 02, 2008 | Technics SL-1200MK2 Turntable
27 people viewed this question
 Grubhead
Grubhead
