2003 yukon xl
Display keeps changing languge by itself
MrScary66613
  • 1990 Answers
SOURCE: temp sensor and compass not displaying on my 2003 yukon xl
Yes. Look in the Fuse Panel inside the Truck. Use a Good Maglight or LED Flashlight and Hold it Behind the Fuses to see the Blown Ones. It is usually in an AUX Outlet. Also check thr Fuse Relay Box under the Hood for a Blown Fuse using the Same Method. See if there is a Relay for this also. If so, Replace it. Let me know if you need any more Help! Please Rate my Response, I need all the Help That I can Get!
Posted on Jan 26, 2009
  • 124 Answers
SOURCE: 2003 Yukon XL Front passenger side door: Electric
yes it does sound like that is your problem. try checking for used one.
Posted on Mar 11, 2009
  • 94 Answers
SOURCE: 2005 gmc yukon xl denali service ride control
it has to do with your air ride suspension best bet is take it to the dealer there is probably a problem with a level sensor. hope this helps you
Posted on Mar 16, 2009
SOURCE: The Heater fan in my 2003 GMC Yukon XL will not turn off
I don't know if you already fixed it, but I had the same problem on my 03 yukon, TysonRicky is right. In my case it was the blower control module. You can find it right under the glovebox. It cost me close to $100 for a new one, but very easy to replace. Can't even imagine how much it would've cost me if I had a mechanic do it.
Posted on May 19, 2009
reactman
  • 297 Answers
SOURCE: 2003 Yukon XL outside temperature
There probably is a fuse, and your owners manual should say it. If not that does not work, there may be a faulty thermometer, and the book will also list part #s, and more helpful, where it's at.
Posted on Dec 19, 2010
How do I reset the ECM?
2003 GMC Yukon XL check engine light run - YouTube
? 1:21
www.youtube.com/watch?v=Rt06jXNGJT0
Mar 31, 2014 - Uploaded by Antonio Salinas
2003 GMC Yukon XL with a check engine light on. ... HOW TORESET CHECK ENGINE LIGHT, FREE EASY ...
Oct 02, 2015 | 2003 GMC Yukon XL
What could be the problem, my 2003 Yukon xl has an oil leak after a recent oil change
I would check the oil filter. They may have left the old gasket on which will leak.
May 06, 2013 | 2003 GMC Yukon XL
2003 yukon xl 1500 "service air bag"
It probably needs a service by a competent garage.
Mar 11, 2017 | 2002 GMC Yukon XL
I have a 2003 yukon Problem with the GMC Yukon XL
What size engine ? 4.3 L vortex P0300 random misfire code is usually associated with vacuum leaks , but could also be low fuel pressure , plugged fuel filter , fuel pump problem , clogged injectors etc... doing fuel pressure an flow testing would confirm or eliminate that as a problem . Fuel injector balance testing would confirm or eliminate clogged injectors .
Mar 24, 2017 | 2003 GMC Yukon XL
My a/c is just blowing thru the windshild area and not the front vents.when i change the setting on the controls the arrow move on the control display but it still comes out the top .its a 2003 gmc yukon...
Hi Victor,
I am having the same problem with my 03 yukon, it just started after i changed the battery.
did you every get it fixed??
Please respond to kevsel@hotmail.com,
thanks in advance,
Kevin
May 26, 2010 | 2003 GMC Yukon XL
How do i resent my change oil warning on my 2003 yukon
AH yes an easy one. Turn the key to the on position, press the accelerator pedal down 3 times and then on the 4th one hold down to the floor and wait for the display to reset. Turn the key off and verify it reset.
Feb 27, 2010 | 2003 GMC Yukon XL
Temp sensor and compass not displaying on my 2003 yukon xl
Jan 26, 2009 | 2002 GMC Yukon XL
Cabin filter for a GMC Yukon XL 05
They no longer used a cabin filter after about 2003. The cover is there buth it is molded shut with plastic welds.
Jan 03, 2009 | 2001 GMC Yukon XL
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
