Cd player draw stuck - Audio Players & Recorders
The CD draw wont open
It sou nds like you have a stuck CD. Most CD players have a small hole on the right side of the drawer that you can poke a paper clip in to open the drawer. Don't push too hard as you might cause more damage than there is. Usually, the CD will come out and the player will work fine.
Mar 04, 2015 | Yamaha Crx-e150
My CD Player Draw Will Not Open
If there is a co in it then it probably fell out and is stuck... especially if it was shaken.... unplug the unit.... remove the screws holding the case together and open it up
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
Cd stuck in Dennon cd player so draw will not close nor can I use the player
Try undoing the screws around the side and back. Top should then slide off and you should be able to remove disc. Make sure it's NOT PLUGGED IN!!
Nov 29, 2013 | Denon Audio Players & Recorders
I have a kenwood multiple cd player dr350 and it won't play cds
Kenwood multiple cd player dr350 draw and cd player has stopped working draw is stuck in and cd player does not work and the skip disc doesn't go round either.
Sep 21, 2013 | Audio Players & Recorders
THE CD DRAW WILL NOT OPEN CLOSE
IF YOU LOOK AT YOUR CD PLAYER YOU WILL SEE A PIN HOLE
PUSH A PIN IN AND THE DRAW SHOULD OPEN HOPE THIS HELP
Oct 05, 2012 | Audio Players & Recorders
CD issue and Battery Dies
Your cd changer is stuck in the read mode and drawing power. Sounds like you need to replace the cd changer before it overheats the wiring and starts a vehicle fire.
Feb 29, 2012 | 2009 Cadillac Escalade
My NAD cd-player has locked it self! I cannot play the cd's or even open to take the cd out. What can I do? Marit
Mine does the same. Press eject and give the front of the draw a sharp tap.. the draw should then open.
Also when loading a disk give the draw a hard shove closed just as it is almost shut - seems to make the disk read ok.
I think both problems are related to a worn / slack tray drive belt... I just haven't been able to find a replacement.
Nov 12, 2009 | NAD C521 CD Player
6 CD Changer Jammed (Audi A4)
You may have to remove the unit and disassemble it to remove the CD that evidently is jammed inside. If your unit has a removable magazine that holds the CDs, the magazine probably is stuck.
Oct 22, 2017 | Car Audio & Video
Home cd player will not open
Look underneath the unit for an access hole . It may be labeled as such.
Some CD units offer a manual drawer open device under there.
If you're really brave, unplug the unit and remove the case screws. Pop off the case and get your CD back. The you might need a draw belt. See prbline.com or studiosoundelectronics.com
May 16, 2008 | Yamaha CDC-565 5-Disc CD Changer
26 people viewed this question
 Grubhead
Grubhead
