Question about The Computers & Internet
(14 × 7) × 12 Which of the following is equal to the expression listed above?
All three sides of a triangle are equal in length of one side is 2x+5 and one side is 4x-3 find the perimeter of the triangle
If all sides are equal then 2x + 5 = 4x - 3
2x = 8
x = 4
so the perimeter is 3 times either expression above
3 * (8 + 5) = 39
Jan 12, 2017 | The Computers & Internet
How to remove wireless card
FOLLOW Anti-Static Procedures
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE, reaching inside your unplugged from power computer.
Computer on a table, computer unplugged from power, computer case open:
TOUCH an unpainted surface, of the metal frame of the open, empty desktop computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
1) On the HP Support page above, click on - How to - in the list.
On the next page click on - Adding/Replacing hardware
Now click on -
Adding or Replacing an Expansion Card (Video Card/Sound Card,etc...)
[A video starts automatically when you go to the above page ]
Your Wireless Adapter Card is based on the PCI Express technology.
It uses a PCI-Express x1 slot,
One of the two small Black slots at the bottom of the motherboard.
(Longer Black slot is a PCI-Express x16 slot. This is for a graphics card - ONLY)
PCI-Express x1 slots, and PCI-Express x4 slots, do not use a Lock on them.
A PCI-Express x16 slot, does have a Lock on it. A small lock arm.
(Gently PULL UP a little, to install graphics card, or remove. It looks like you press down. Nope. Up. )
(Starting at Top, going down;
PCI-Express x4
PCI-Express x16
PCI-Express x1
PCI-Express x16
,and PCI slot.
For additional questions please post in a Comment.
May 01, 2013 | HP Pavilion Media Center m9340f Desktop PC
How do you use the equal sign on the ti-84
The equal sign of the TI83/84/Plus is a relational operator like less than , greater than, less than or equal to) You use it when you are testing if two values (numbers, expressions, or matrices) are equal.
For example, if in one your programs what you do at a certain time depends on the equality of two expressions, you test the equality by a statement :
If A=B do this action.
Jan 30, 2012 | Texas Instruments TI-84 Plus Silver...
Determine the value of x that will make the expression meaningless.
What is the expression?
If it is mathematical, and contains a fraction, and the
denominator of the fraction contains and X, and the
X is part of a binomial such as "a - X" then the
assignment of a value for X that is equal to "a" (above)
then the fraction will become a singularity and it is not
definable: hence: the expression becomes meaningless......
Aug 21, 2011 | Computers & Internet
How do I enter the following problem to get the correct answer? 4.688(6010)^.8168-.0154 log(10)^6010
I have no stake in the outcome of the calculation, but the way you wrote the expression is ambiguous (in my opinion). Look at the screen and see if that is what you meant. Result is displayed. Nevermind the calculator from which I grabed the screen, that is an irrelevant detail.
I notice that you have log(10), and wondered why you failed to take advantage of the fact that log(10)=1. Had you taken advantage of that fact, you could have (log(10))^6010 =1.
Now look athe next screen capture
If the last part of your expression is log(10^6010), a calculator much more sphisticated that yours was not able to handle the calculation, and found an infinite result but the result is finite. If you use the rule of the common logs log(10^6010) = 6010.
I am merely trying to convey the idea that any expression must be simplified as much as possible before typing it.
Now I make use of the rule about the logs
On the last screen, (log(10))^6010 is set equal to 1. The two expressions yiels identical results.
Once you use the rules about the logs, you expression becomes very easy to handle: You have one power to calculate. For that power you use the [^] key, below the [CLEAR] key.
I think that what I showed you above should help you figure out how to enter the expression on your calculator.
Feb 10, 2010 | Texas Instruments TI-84 Plus Calculator
Casio fx-7400G PLUS cubic solver?
First let us repair the terminology.
  1. You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
  2. You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
  3. You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Nov 05, 2009 | Casio FX-7400G Plus Calculator
MS Access: Zero value to display as "New"
Is that field a resultant of an expression or it will be filled manually? If it is a manually updated field then use the following expression in the code builder.
If ok.Value = "0" Then
ok.Value = "New"
End If
If the field is a resultant of an expression then add some more lines similar to above to get required results.
Jul 13, 2009 | Microsoft Office Access 2003 (077-02871)...
Inbox corrupted in Outlook Express 6
if your inbox is coorupted its not possible to access your old e mails but there is a way to make your Outlook express workking
Make sure you close outlook express
You need to go to following location and delte outbox.dbx and inbox.dbx to outboxold.dbx and inboxold.dbx
Open Outlook express it will create new inbox and outbox
Dec 29, 2008 | DBX -215 Home Equalizer
>lets remove Security software and then check
>lets create new identity
and then import the data back to new identity
Nov 24, 2008 | DBX -215 Home Equalizer
Technics SH-8017 Equalizer
use youe tape out signal into the eq's main input and the eq'sout back into the record side of ur tape source.
Jul 28, 2008 | Audio Players & Recorders
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
