Hi we have installed our new mci 6200tw and it function well but unfortunately tv sys function in remote and there is no display but there is audio
4 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: No Video Display, TV is Black. Have all audio and remote functions
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Posted on Jun 29, 2008
  • 9 Answers
SOURCE: Remote does not function
or see if a new $20 remote will fix it... fixed mine!
Posted on Jan 22, 2010
SOURCE: New RC-737M remote has not
On installing the Nex Remote on my PC an error is occuring : NexRemote is not allowed ot install on WinNTx
Posted on Oct 19, 2010
On off button on bush remote not working, we have to use buttons on tv unit, all other functions work fine
Hi, if all of the other functions of the remote work fine, then I'm reasonably sure that it is the contacts under the on/off button itself that is worn out.
Unfortunately there isn't an easy way to replace or repair that.
You can however find a replacement remote for that TV here:
https://www.remotes.com/
May 03, 2017 | Bush Televison & Video
Codes for tuning bt vision box to sanyo tv
Here are the codes:
First try the 4 digit ones:
0136, 0242, 0722, 0732.
Now try 3 digit ones:
106 154 155 156 157
160 208 210 216 267
275 282 316 319 320
322 360 0236, 154,182 ,190, 191, 220, 221, 278, 282, 283, 323.
Goodluck..
Feb 14, 2008 | Televison & Video
I connected mediacom karaoke MCI 6200TW premium to LG tv. Start up sound heard but no video came out.
It would depend on the cord that plugs into the tv. If you have the red, yellow, and white that plugs in then the video cable needs to be plugged in. You need to plug in the video cord. It sounds like you only have the audio cable plugged in. Try a hdmi if there is a outlet for it.
Jul 15, 2016 | LG Televison & Video
Do you know the sky+ remote code? So I can operate the volume control on the sky+ remote. I've tried loads already hope you can help.
It would help to know the model number of your LG TV. However, you can try the generic codes for LG which I've listed here:
Rev 8 remote: 1293, 1206, 0206, 0065, 0904
Rev 6 remote: 0065, 0742, 0502, 0672, 0634, 0136,
Rev 4 remote: Same as Rev 6
RC1600/00 remote: codes not available and unlikely to work with your TV
** Your Sky remote version can be found on a sticker inside the battery compartment. **
Try these codes but if they don't work, please post back with your TV model number. It's possible that your remote does not have a code which will work with your TV, in which case, you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due but I've not been able to confirm this yet.
Hope this helps - please post back if you need further assistance.
Regards,
BElectric
Nov 25, 2010 | LG Televison & Video
I have just purchased an LG32lcd 450 tv, I cannot get the handset on Sky to work as they do not have a code to do this as the tv is new to the market, can you please help with this
OK, as you already discovered there is no specific code for your remote. You can try the generic codes for LG which I've listed below. Your TV may use the same flash patterns as some other older LG TVs so these codes might work.
Try these codes but if they don't work it's unlikely your remote will work with your TV - you will need to use the remote supplied with your TV to control volume and power functions. Unfortunately, when a TV is newer than the remote and uses a new flash pattern not programmed into that remote, the remote wont work. However manufacturers often keep the same flash patterns for common functions, so the generic codes might work for you.
I'm informed that a new Sky remote version is due - which will hopefully contain a specific code/flash pattern for your TV - but I've not been able to confirm this yet.
Nov 23, 2010 | LG Televison & Video
I purchased umax tv 5821 last week .i set my tuner with HCL 19" wide screen,after 2 days there is no picture on the lcd.and pop up showing that input is not supported.only voice is listen but there is no...
Hi deepak,
you have changed your display settings by mistake.from the sys key on ur remote control there are 7 display resolution and frequency options.though u r unable to get the display, press sys key one by one with 10 sec pause untill u will get the proper display.
further u can mail me on himanshu.m@microvillage.in
Sep 21, 2010 | Computers & Internet
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
The channel stays lit in the upper right corner
Unfortunately, you almost always have to have the original remote control to get this display to go away. The "display" button is a specific code on that remote.
With Dish remotes, though, sometimes you can try different buttons and they will occasionally operate different functions. In TV mode, try the menu orother buttons to see if it makes a difference. My suggestion is to call a TV repair shop and see if they will allow you to borrow/buy an original remote for that TV.
Hope this helps you...
Jan 06, 2009 | Sanyo DS31590 31" TV
TV Remote
hi,
I posted a fix on one other thread, you can get a universal remote to acces that function, newer directv remotes have the menu function
J
Jun 19, 2008 | Disney 13" TV
Button Problems
What is the model# for your remote? It's hard to trouble shoot the error with out checking the information on the correct remote. Let me know so we can check into it further for yah!
Sep 20, 2007 | Samsung SAM1100 LCD Remote Control
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
