Question about AMP Car Audio & Video
What goes in slot number CON1 I inside icbm 894 amp curcuit board
2 Suggested Answers
  • 113 Answers
SOURCE: icbm-892 amp performance teknique on protection mode
see what the volts and uf are and u can desolder the old one with some solder wick and find a replacement out of some old junk electronics that is the cheapest way I have done this many times and the used one does not have to be black
Posted on Jul 05, 2009
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
Need to see the diagram to bridge amp
Bridging an amp is as simple as using both channels for one hookup. By this i mean use the negative slot from one channel and the positive from the other. Not all amps are bridgeable however, so if yours is there will be a line showing which channel to use the positive on and which one to use the negative on.
Aug 10, 2012 | Performance Teknique ICBM-Digital Car...
The model number is Kenwood KA-894 integrated Amplifier I'm trying to find out how many watts. Thanks
The manual with 'specs' is here. Take them with a grain of salt because it's impossible to produce more audio watts than are consumed electrically (250 total).
http://www.retrevo.com/s/Kenwood-KA-894-Amps-review-manual/id/479ag211/t/1-2/
Dec 25, 2010 | Audio Players & Recorders
Icbm-892 amp performance teknique on protection mode
May 07, 2009 | Performance Teknique ICBM-892 Car Audio...
Wont recognize new memory?
First try to reseat the memory, if it is still showing the same amount, then you may have a bad stick of memory, remove both and insert 1 stick into Dimm 1 slot and see if it still registers 894, then put the other in the same slot and see what it registers. Then try in the Dimm2 slot and see if you get a different reading Depending on the manufacturer, it may only show that amount since Windows shows memory different that the memory manufacturer.
Hope this helps.
Mar 10, 2009 | Toshiba Satellite A135-S2386 Notebook
Lasko fan has stopped ocillating (hoped I spelled that right)
You might also check for a loose wire in where the wiring harness goes to the oscillating motor. I had this problem and one of the wires had pulled out of one of the wire nuts inside a wiring compartment.
Aug 16, 2008 | Lasko 2530 Elite WindTower Fan
My amp has power the led is on but no sound
See what happens if you apply a temporary ground connection to the RCA input jacks ground connection while it is running. You might want to turn the volume down before you do this just in case it works.
Jun 25, 2007 | Performance Teknique ICBM-894 Car Audio...
Car Audio & Video Logo
Top AMP Car Audio & Video Experts
bigdawg7299
Billy McCain
Billy McCain
Level 1 Expert
Are you an AMP Car Audio and Video Expert? Answer questions, earn points and help others
