How to attache driftwood
Making driftwood lamp need to secure base to light
How do I stop light from flickering
Lamp has loosened from the base. Just screw it back into the base. Secure the lamp to the base with one wrap of clear scotch tape.
Sep 26, 2014 | Panasonic Microwave Ovens
My tornado lava lamp doesn't work. A little plastic piece just bounces around on the bottom.
It's difficult to say based on your limited description. A lava lamp is a first of all, a lamp. Does the incandescent lamp light up? If not, replace it (it's the heat source which creates the swirling action in the attached "lava" globe). As for the plastic piece, perhaps it's part of the lamp-holder socket that broke off due to heat. Perhaps part of the switch.
In any case, the light light bulb probably burnt out. Believe it a standard 40 watt bulb, but be absolutely certain to check before replacing as you do not want to put a bulb with a higher wattage in there due to the confined space inside the lamp.
Apr 13, 2014 | Novelty Lava Desk Lamp
I have a clarke bench grinder model 1002. I have a light that I would like to attach into the wiring though the grinder wiring in it's base. The light has two wires, and the grinder has a ground that...
Attach the white wire on your lamp to the white wire on the grinder.
Attache the black wire on your lamp to the black wire on the motor side of the switch.
This will give the lamp power any time the grinder is turned on.
You can put a switch inline of the black wire to the lampp and it will allow you to turn it off when not needed
You can attach the white wires together and the black ones before the switch.
If you choose this way you will need a switch as the lamp will be power all the time.
May 21, 2011 | Vacuums
I have a 55" sony
According to the manual (you can see it here) page 122 that describes 3 red flashing lights:
"The lamp cover is not attached securely. When you secure the lamp cover, the POWER / STANDBY light flashes in red and the LCD projection TV enters the standby mode (see page22)"
Page 22 says:
"... if the POWER / STANDBY light flashes continuously, this may indicate the display unit needs servicing..."
Most DLP displays make use of a "color wheel". These small motors spin at many thousands of RPM. They often begin to make scratching sounds when they are beginning to fail. Some manufacturers make it difficult to change yourself - and others make it pretty easy.
I hope this was at least a good starting point for you & good luck. Please rate my reply. Thank you.
Apr 04, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
KDF-70XBR950 70 in. Rear Projection HDTV Television My TV took a power surge and I?m getting the 3 blinking lights, I read online that it?s probably my g3 board. I check the lamp and the cover but...
3 times red standby blinking light indicates Lamp Cover is not attached securely or Lamp has not been fixed properly inside tv. Make sure lamp and lamp cover are securely attached in tv.
I do not think G3 board is bad because 3 times blinking error is related with lamp cover that engages micro switch inside tv.
Let me know your findings to provide you more helpful info.
You can download service manual from This Site for little fee.
Jan 14, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Having trouble fixing brake lights
Tail/Turn Signal Lamp Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Oct 13, 2010 | 1997 GMC Sierra
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony tv kf-42we610 tv will not come on and red light blinks three times
Three flashes usually means the lamp cover is not attached securely and the TV has gone into a "stand by" mode, recheck that the lamp,lamp door, and front panel is securely attached.
Good Luck !
Feb 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Power to light on WD-73727...
This cable attaches to the lamp,reach in behind the lamp case in the tv and hold it in place and reinsert the lamp make sure it plugs into the lamp securely.
Aug 22, 2009 | Mitsubishi WD-62725 62" Rear Projection...
How to change lamp in AGFA Arcus 2 flatbed scanner?
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Nov 16, 2007 | Agfa Arcus II Flatbed Scanner
    Televison & Video Logo
    27 people viewed this question
    Top Televison & Video Experts
