Question about Electrolux Washing Machines
I have a electrolux XL8- I think the pump is blocked, how do you get the front cover of the machine to find pump?
3 Suggested Answers
  • 353 Answers
SOURCE: how remove front cover on pump to see if blocked? - servis m6666
remove pump from machine then 3 screws and it will come apart It might stick a little don't lose the seal
Posted on Dec 15, 2009
richroth
  • 9472 Answers
SOURCE: Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
I have an Electrolux ewf14811 washing machine the handle has broken and I need to open. Any suggestions
yes
you need too pull the machine out
and take the two screws out each side of the top plate
slide the top plate too the front and lift it off
with the main power removed !!!
reach down to the door catch you easily lift the peg clear
if you just with you knee push the door in a little
so this way youll be able too edge the door out
and recover your washing
i think the motor has failed for spin
or the filters are blocks on the pump side
or the pump has failed
perhaps a wire from clothing or a coin has jammed its viens up
so clean the pump usually there is an access too it
from the front panels
if your not sure then ask a tech for help
will cost like no more than £30 uk dont pay more
Mar 05, 2015 | Electrolux Washing Machines
E4 error code on electrolux washing machine ewt 854s
E4 is the pump is blocked {not running} pehaps a hair pin or clothing wires get stuck
fully drain it and take the filter out
and clean it
these error codes are similar to candy
youll get an idea from this video
https://www.youtube.com/watch?v=kzhlvB2LjXg
Nov 28, 2014 | Electrolux EW1000i Front Load Washer
Affinity front loader wont drain
Blocked the pump try putting a cleaner through the machine,check pump for obstruction.
Jul 26, 2014 | Electrolux 134743500 Fridgidaire Washer...
Nov 09, 2012 | Washing Machines
Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Jun 23, 2011 | Electrolux EW1000i Front Load Washer
How remove front cover on pump to see if blocked? - servis m6666
Dec 14, 2009 | Washing Machines
I think it needs new water pump it does not drain the water
More likely to be a blocked filter, or pump.
Look for a filter at bottom front of washer, possibly behind a plastic cover, turn anti-clockwise to remove.
Please rate my solution.
Thanks.
Nov 15, 2009 | Whirlpool AWM5104/1 Front Load Washer
I have a 6.5Kg electrolux front loader washing machine it needs a new pump and circuit board... where can i get one of these from????
sorry - no idea - but just mentioning that sometimes pump is blocked by bits of cloth - which is easy to free once you remove pump - this also stops machine continuing normal cycles - i thought mine had problem with the circuitry as it didn't progress automatically but after clearing cloth out of pump it's back to full swing!
Nov 01, 2009 | Electrolux EW1000i Front Load Washer
Broken front loader washing machine
take the back off and see if the belt has come off. is it draining water? if not make sure nothing is blocking drain pump
Apr 23, 2009 | Electrolux Washing Machines
Washing Machines Logo
37 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
