Is screen width adjustable on Bravia KDL-40XBR4? Since new, we lose too much on both sides, regardless of which screen width we select.
    Top Expert:
  • Televison & ... Master
  • 50,554 Answers
On screen menu to adjust the aspect ratio or use the pixel settings to adjust screen size
Posted on May 11, 2017
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
NO PICTURE OR SOUND ,GREEN LED STAYS ON FOR 10 SECONDS THEN A RED FLASH . PROCESS REPEATS ITSELF
Hi
You have to check how may time that led flashes. check the link for more details about led blinking in sony bravia tv.
www.electro-medical.blogspot.com
Mar 18, 2015 | Sony KDL-40XBR4 40 in. LCD HDTV
Sony bravia kdl 52w3000 picture adjustment. The picture is too bug for the screen. I cant figure out how to shrink it.
I have a different Sony, but I think they all work the same. Go to menus (Press Home) Then select "Settings" and select "Screen Settings". Set Wide Mode to "full", Auto Wide to "off" , Auto Display Area to "off", Display Area to "normal". I hope this works for you
Sep 16, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Mar 06, 2011 | Sony Televison & Video
I have a sony bravia kdl-40xbr4 since nov 2007 and tv has started to give me ghost lines in the right side, from what i understand this could be the panel or the video board. sony wants me to get it...
Ghost lines or distorted lines is problem of lcd panel. Main board is working fine without any problem.
LCD Panel replacement would cost you new tv price so its up to you to replace lcd panel in this tv or buy new one.
Thanks.
Nov 17, 2010 | Sony Televison & Video
Broken, Cracked screen on my sony kdl-40xbr4
Price
4,003.02 Not Available for Backorder There is a credit for the return of a useable core; but since yours is broken it probably would not be available...
Oct 17, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
The picture has a shadow
you're LCD panel is gone. To replace it...$1500-$2K. But there is a silver lining to this dark cloud. No pun intended. Sony has posted on the US and Canadian site they will repair the XBR4 at no cost! i have the link right here. http://www.sony.ca/view/882.htm Canadian. http://esupport.sony.com/US/perl/news-item.pl?news_id=378&mdl=KDL46XBR4 USA.
It claims its the 46" but it appears to be a 40-52" problem. If you have an extended warranty it will pay for it.
Apr 06, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
Can I replace a broken screen on a sony KDL-40XBR4? thanks for your advice and time. kirby
Yes, you can replace broken screen of Sony KDL-40XBR4
I can give you its part number, and it would be fine if you paste snap of broken screen here to understand the exact problem.
Thank you.
Sep 21, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
