Question about Storm Computers & Internet
Hello: My alarm is flashing "power". Has it just been tripped due to a storm and if so, how to fix. Or, do I need to replace the battery which is only 4 years old. Thanks
SOURCE: Sceptre power supply short circuit
I have the same problem. TV was JUST out of warranty. Sceptre part number is X37SV-Naga and the cost - $285.00 plus $20 shipping. Non-refundable, no returnable.
The TV is of course going to de-solder the board within a year again, so either a good heat sing on both thermistors is in order OR a law suit against Sceptre is in order for putting us a risk of fire.
Posted on Jul 09, 2008
SOURCE: Samsung HTDS610 Home Theater System power wont stay on!
I did my research and this is the solution:
Your HT system is overheated and the fan is not working. Just replace the fan and you will be good to go.
Ken
Posted on Sep 24, 2008
dsacco86
  • 1077 Answers
SOURCE: SYLVANIA 42 INCH 6842PEM DOES NOT TURN ON
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
Asbestos 56
  • 191 Answers
SOURCE: the lights and fan didn't
There may be a reset, but it may be due to a power surge burning out the controller board.
Posted on Jun 24, 2011
I have an aftermarket alarm system that has drained my battery
Dear Mary. All car alarm systems drain the battery after one week of the car not being used. Also, car batteries are not always fully charged on short trips because to start the engine on each short trip it drains a tremendous amount of power and a short trips do not recharge it fully. Have the car battery checked because the alarm is always on and on standby once installed, they usually have a small back-up battery in the alarm in case of car wires to the alarm have been cut, but that battery is always kept charged by the car battery, so, that is only causing a fraction of car battery discharge. However, to stop it from draining the battery you have to disconnect the alarm, and that is not a good idea. No car alarm that I have known have caused any car battery discharge, but of course if the car is not being used, or it is driven for short periods you are likely to experience a drained battery. Some batteries last more than 5 years not stop while cheaper ones have a lesser life expectancy, but again that depends on a lot of factors, heat from the engine, not enough charge because the alternator has a burnt diode, interior lights left on, too much cranking of the engine to start it and not enough miles done to recharge the battery. Try to get the battery checked and if you do not do any driving for a week, there are a number of solar powered battery charging panels that trickle charge it on sunny days but in winter I suggest you buy a charger that you can connect to the battery to keep it charged. Once charged the charger automatically cuts off and stays on stand-by until the car alarm has discharged it a bit, then the charger sensed the voltage drop and recharges it again, repeating the cycles until you need the car to go out. These small car battery maintenance chargers are inconvenient if you're not using the car too often. Some car alarm with go off when the car battery is disconnected. It's part of the protection the alarm offer. They may not be disconnected from the car battery unless you have a key that shuts off the alarm. But remember, the key shuts off the alarm but it doesn't mean it has disconnected the power from the battery. Check the pilot light status. If it flashes after the alarm key has been turned to off, it means the power is always there. Other alarms remain silent when the car battery has been disconnected from the clamps. If you garage the car at night, you can have a switch installed in the car that switches on the power to the car alarm or you can have the switch connected to a special relay activated Kill Switch that disconnects the battery altogether, but if your car alarm starts to squeal, then you don't need this switch. so try it first, disconnect the car battery and see if the alarm goes off. If not, then the Kill Switch is an option. If it goes off, then there is nothing you can do but to try and have the car battery checked and if you're not driving much or drive short trips, either a solar charger or a Mains powered auto charger can be used to keep the battery trickle charged. But before I go, you say you got an after market car alarm. Looks like it has been wrongly wired, who know. Have it checked by whoever installed it. Good luck.
Mar 17, 2015 | Jeep 1999 Grand Cherokee Laredo
Potterton suprima 30 80 keeps tripping out red light flashing
Hello, like your failure is due to the generator is generally low and the battery energy storage performance degradation, it is recommended that you check the engine power and the energy storage performance of battery, as well as the link of the body by iron wire, according to specific situation for repair.
you want solve this problem please :diagnostic tool
Mar 22, 2013 | Cars & Trucks
99 subaru forester. No power at all. When I wiggle negative battery cable : power comes back and alarm is triggered. But power fails again if I turn key or touch brake pedal. How do i fix this?
Bad battery (have the battery tested) Bad connection, corrosion on the terminal and in the cable, replace the cable, recharge the battery to full charge.
Sep 13, 2011 | 1999 Subaru Forester
Toshiba Model 51H84. Power breaker tripped during a storm. Breaker reset, and TV will not power on. Is there a fuse? Is there a reset button of some sort? How should I proceed? Thanks.
Your TV has a fuse on power circuit board ( that is a standard part).You need to resemble your tv to get the fuse ( make sure to disconnect all power and antenna before doing this service). Usually any tvs use a clear glass cover on fuse ( you can see a small conductor inside the glass). Replace the fuse if the small conductor gets broken. If after the fuse replacement, you got no joy on tv, the receiver part could be get problem also ( due to storm attack) and need to repair / replacement.
I hope the storm only attack your TV fuse.
Good luck
Aug 02, 2011 | Televison & Video
Had the alternator replaced 2 days ago and during the night the alarm goes off lights flashing honking use the key fob to turn it off and takes a while for inside light to go out stays quiet for a while...
Hello, sounds like you need a new battery. As the battery goes flat the alarm senses it and sets off the warning system. Try changing the battery first and test it during the day. Also check to see if there is anything draining the power. You may also be able to adjust the alarm settings manually. Failing that, the alarm may need replacing. I hope I have helped.
Mar 24, 2011 | 2003 Chrysler PT Cruiser
We experienced a Sevrer Thunder Storm in our City on 07-23-2010 and as a result had a power outage for several hours. Once the power was restored, the Haier 3.5 cu ft chest freezer is no longer working and...
Hello
Due to the heavy storm you experienced,and since the freezer was plugged during that period there might have been a negative effect from the storm on your freezer due to earth.All you need to do is to get a technician to check it out.
THANK YOU
Jul 28, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Power went out in my house due to Snow Storm. My
it might be that it short circuited. try to remove the battery, unplug the ac adapter2_bing.gif and press and hold the power button for about 15-20 sec to drain power. expect no response since we're just draining the power. then put back in the battery and ac, and try to turn pc on. if still no go, possible motherboard replacement.
Mar 30, 2010 | Sony VAIO VGC-RB40 PC Desktop
2003 Gr. Cherokee Tire PMS overactive with smaller sidewall tires
Hello partner. The difference in air pressure variations from a 16',17' or 20" tires is a non-factor. Any size tire will go up about 1psi per 10 degrees ambient temperature. The recommended pressure for an 03 Grand Cherokee is 33psi. So if it's a rainy 55 degrees in the great northwest when you set your pressures the temperature on your trip to Death Valley would have to climb to about 175 degrees. On a different note maybe your alarm just isn't calibrated correctly.
Apr 10, 2009 | 2003 Jeep Grand Cherokee
Computers & Internet Logo
24 people viewed this question
Top Storm Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
richie46
Are you a Storm Computer and Internet Expert? Answer questions, earn points and help others
