Question about Dryers
I have a hater dryer that does not get warm what is the problem
  • 84 Answers
Element is burnt !
Posted on May 15, 2017
My passenger side is blowing warm air
Sound like you have a blend door actuator that had stopped working. You have cold AC on the drivers side but not the passenger side? Your car has dual zone climate control where you can adjust either side independently. If you have cold air when you ask for it and hot air when you ask for it then the overall system is working properly, it is just that one side is not moving the blend door between the heater core and the evaporator core. Either you have something inside of the hater box that is keeping the door from moving or that hte motor that is suppose to move the door has quit.
Apr 21, 2013 | 2004 Lincoln LS
How to test ECT sensor? 2002 jetta TDI, temperature indicator would go up and down but car was warm and hater output ok
Replace bad Engine Coolant Temperature (ECT) sensor. ECT sensor is placed in the right back side of the cylinder head on 2002 VW Jetta 1.9 TDI. See picture below:
Mar 30, 2011 | 2002 Volkswagen Jetta TDI
It appears that the drum belt has come off or has snapped.
Jul 06, 2010 | Frigidaire Electric Dryer
I turn my indesit is70c tumble dryer on and after a minute it trips the rcd. I then reset the rcd and turn it back on and it runs for about a minute and then trips the rcd again. Can anyone help me with...
this could be the hater or the motor but sometimes just chafed wireing
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "h_WMwQ-M33A" placeholder (do not delete)
We have a full video library on appliance repair video’s
Jan 03, 2010 | Dryers
My Maytag dryer will not stay warm
replace gas valve coils kit
Aug 16, 2009 | Dryers
Heater coil
have to remove drum to acess hater coil ..all ge dryers are behind drum ck continuity first also ck for burnt wires
Sep 04, 2008 | GE Dryers
Breaker tripping
The problem may not be with your dryer but with the circuit breaker...
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 14, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
