Question about Global Office Equipment & Supplies
I normally work on my TI Nspire CAS CX in "FLOAT" but I need scientific notation for this one line of math. Is there something that I can use do I have to change my global settings every time?
If I want to keep my TI Nspire CAS CX in "FLOAT" but I need to have this large number displayed in scientific notation, is there something that I can use to convert this one time situation or do I have to change my global settings every time I need to see a scientific notation number (I normally work in float).
4 Suggested Answers
  • 1536 Answers
SOURCE: how to convert a normal ANSWER to scientific
It's been a while since my TI calculator died, but I think you can just hit EE (may be "exp" on your model) followed by =.
Posted on Aug 28, 2009
  • 10 Answers
SOURCE: My Ti-nspire is set to Float. However, on the box
Float on the t-nspire essentially means round to the nearest whole number. Your best bet is to set float to a higher number.
Posted on Mar 05, 2011
SuperTech-11
  • 1591 Answers
SOURCE: my caculator (ti-83) is not
244140625 is the answer to 25^6 but as for your issue, if you are in scientific mode and punch in 25 X^y (X to the power y) 6 and then press enter, it should display this result.
My guess is simply that you aren't pressing ENTER to get the result of the calculation since we know the calculator is more than capable of displaying the above result on it's screen!
Posted on Mar 27, 2011
Hi! I have a TI-nspire CX CAS and I was wondering how to enable the results to be shown in thousands separators (1,000 or 1'000). Thanks for your help!
At first press on key, then Settings and finally Document Settings. From this menu on the position Base choose Decimal. See captured image below
Dec 22, 2015 | Texas Instruments TI-Nspire CX CAS...
TI-nspire cx changing from degrees to radians
Press Documents Settings. On line angle select radians, AND validate the change by moving the cursor on the OK button, and pressing it.
Jun 12, 2014 | Texas Instruments TI-Nspire CX CAS...
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
Need calculator that does calculas
Some calculators that have a CAS (computer Algebra System) are the following
TI Nspire CAS, TI CX CAS, TI92 and TI 92 PLus, TI 89 Titanium, TI Voyage 200 PLT.
Casio FX Algebra 2.0 PLus, Casio ClassPad 330, 330 PLus, 400
HP 48 G, G+, GX, 49 G+, 50 G
Jan 17, 2014 | Sharp EL-531VB Calculator
My TI NSPIRE CX CAS is stuck at the loading screen - it keeps loading and then going back and repeating (only when plugged in). I have tried resetting it whilst holding down EE, doc and enter. When I do...
restarts.
unit.
Please note that the second and fourth option will require that the OS will need to be reinstalled.
Oct 09, 2013 | Texas Instruments TI-Nspire CX CAS...
How to get the ti nspire cx to give square root answers
You can not achieve this with the Ti-nspire cx. Only the CAS version will give the square root form. On the CAS there is an option in the settings called "EXACT" under calculation mode. The cx does not have this mode.
Jan 09, 2013 | Texas Instruments TI-Nspire Graphic...
My ti nspire cx cas is totally stuck at the loading screen , it keeps reloading and reloading with a sign at the left corner at the bottom that say's that my battery is empty ? what should i do ?
I have a doubt, when I choose to completely format the calculator it will clear your operating system, files saved on it, but the product key (ID protuto) will be deleted too?32d3cd84-9b87-4f5d-abfe-aa04ca86df4c.jpg
Dec 18, 2012 | Texas Instruments TI-Nspire CX CAS...
Hi, I have a problem with ti-nspire cx cas.
The Ti Nspire CX CAS has a built in battery. It must be recharged. If you plug it in a wall socket or in a USB charger you should be able to use while it is being recharged.
Nov 22, 2012 | Texas Instruments TI-Nspire Graphic...
How do I set up my TI-nspire to show a large answer in scientific notation?
In OS 3.x Press 5:Settings>2;Settings>1:General.
In the screen that opens, use TAB repeatedly until you
reach the line : Calcul Mode. Use right arrow to open
that menu. Select the option APPROXIMATE and press
ENTER. Use the TAB to move the highlight on the OK
button and Press ENTER/OK to save the changes.
All large values will be displayed in Scientific Notation.
Aug 30, 2011 | Texas Instruments TI-Nspire Graphic...
27 people viewed this question
Top Global Office Equipment & Supplies Experts
k24674
Are you a Global Office Equipment and Supply Expert? Answer questions, earn points and help others
