LED Tv picture is dim. Checked the settings nothing helps including turning off power save. New Tcon. No bad caps on power supply. Have backlights. Can see image it is just very dim.
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on May 11, 2017
Hi there, my Samsung TV turns on, but the screen is black and the audio works. I changed the main board and power supply/LED board. I'm thinking the T-con board but I just wanted your opinion.
Maegan,
You have already changed power supply/led board and main board. What is left now is the tcon and scaler board. Please try tcon.This may solve your problem. By the way, there is a systematic way of singling out the faulty board. A little research on this will save you save you time and money. Good luck.
Jan 22, 2018 | Samsung Televison & Video
RCA Model L40FHD41YX9 Will Not Power on. No Sound or Picture. Found cable from power supply to Backlight inverter connector burned. Replaced cable power supply and backlight inverter and main board.
Going by what all you have changed with no results its sounding like the actual CCFL lights are bad or at least one of them...there should be several sets of wires going to them from the inverter board, you can unhook them one at a time and see if you get some light on the screen, unfortunately though it sounds like the set may be on its way to the recycler. I assume if you look in the back of the set with the lights off you don't see any light.
Nov 08, 2017 | RCA Televison & Video
My samsung led tv, when i turn on red light blinks 6 times. no display, no sound. Tried replacing power board, main board and tcon board, all of them seems to be fine. What else could be the problem.
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
Oct 26, 2017 | Samsung Televison & Video
LED TV has sound but no picture?
Sounds like it can be because of the faulty LED's. The LED is drawing over current for the power board that's why the fault arise again. There would be no fault in main board or the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 03, 2016 | Televison & Video
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
Apr 04, 2016 | Samsung UN46EH5300 - 46" LED-backlit LCD...
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
No picture on screen only sound
Flat-panel LCD TVs have a lifespan newly approaching 100,000 hours on average. The lifespan of an LCD TV is generally longer than that of similar-sized plasma televisions. Some manufacturers even claim that their LCDs can last upwards of 100,000 hours when used continuously under controlled conditions (e.g., in a room with "standard" lighting conditions and 77° temperatures throughout). Just how realistic such claims are is debatable. After all, whose living room has no windows and remains at a perfectly comfortable 77 degrees year-round?
In any case, the pictures on fluorescent backlit LCD TVs will show some "wear" because they are generated by powerful lamps, which, like any lighting appliance, will dim over time and with use. The picture you see will dim ever so slightly as the backlighting bulbs dim. One other consideration is that CFL fluorescent backlighting will change colors over time. This will change the white balance on your TV and cause color calibrations to be thrown off.
Therefore, the most important thing to consider when it comes to the lifespan of your LCD TV is the actual lifespan of the light source in your LCD. LCD TVs last as long as their lightsources do. So, the lightsource in your LCD TV is the critical component of your LCD display unit. Newly introduced LED backlit LCD TVs will have the best long term performance. LED backlighting is superior in that the white balance of the TV will not be affected by changing bulb color over time. It's a more consistent bulb technology and will also maintain its brightness longer.
The edge lit version of LED TVs will use far less energy while local dimming LED backlighting will be more accurate and present a better picture while using more power. We believe that local dimming LED backlighting will be slightly less stable from a life span standpoint.
To ensure the integrity of your lightsource for the duration of your LCD display's lifespan, you will definitely want to adjust the CONTRAST setting of your LCD TV. Too high of a CONTRAST level will prematurely age your lightsource because it will have to work harder to maintain such light intensities. Your best bet is to keep your CONTRAST set appropriately for the conditions under which your view your LCD display. Brighter ambient light levels require slightly higher CONTRAST levels, while lower ambient light levels demand less CONTRAST
If there is sound but no picture, only sound it has more chances of faulty back light repairable from Service Support.
Hope this helps, if so do rate the solution.
Jan 28, 2011 | Samsung Televison & Video
Why does my TV have sound but no picture?
Hello
To ensure the integrity of your lightsource for the duration of your LCD display's lifespan, you will definitely want to adjust the CONTRAST setting of your LCD TV. Too high of a CONTRAST level will prematurely age your lightsource because it will have to work harder to maintain such light intensities. Your best bet is to keep your CONTRAST set appropriately for the conditions under which your view your LCD display. Brighter ambient light levels require slightly higher CONTRAST levels, while lower ambient light levels demand less CONTRAST.
Hope this helps
Jan 08, 2011 | RCA Televison & Video
Tv shut off
Common failure in this TV is the caps in the power supply are bad and also failed 5VDC standby supply stops working (if you do not see red indicator light on the front panel, the it is bad), and backlight inverter bd.
Please see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Power supply: http://www.google.com/products?rlz=1T4GZAZ_enUS358US368&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=dhUNTI2sDpK-Nt6QwLUE&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCkQrQQwAA
Jun 06, 2010 | Protron PLTV3250 32 in. LCD Television
Techwood 32'' LCD, screen is black, no sound.
the light you see is the backlight, you have either a bad signal board or tcon board which is part of the screen usually.
only cheap solution may be if the capacitors on the power supply, if you want you can do a visual of the power board caps will appear swollen on top and are easy to solder in cost about $1
try reseating the thick cable running to the panel (Tcon board) top center inside the set
Jul 26, 2009 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
