Question about Magnavox Televison & Video
Magnavox 35 TV won't boot up. Had cable tech come and check it; he had same thing as I: Red light will blink, but then go back to steady red instead of turning TV on
    Top Expert:
  • Magnavox Master
  • 75,462 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on May 11, 2017
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
Nov 01, 2015 | Philips Televison & Video
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Own a mitsubishi WD-52525 52 in. Rear Projection HD TV. Already been through the "blinking light of death" problem about 2 yrs. ago. Now have a steady red lamp light. Purchased new lamp, installed, and...
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. sounds like caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use the table below -
You can buy replacement caps from Mouser electronics online
Sep 11, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No sound, no picture. tried unplugging and plugging back in...same problem. the green power light just keeps blinking 14 times over and over again. tv is around 11 yrs old...philips magnavox 32" smart...
check your h-out transistor, in high voltage area, capacitors and resistors, need reservicing and resoldering....hope you can do it, or check out with qualified tech
Oct 25, 2009 | Philips Magnavox TS3260C 32" TV
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Televison & Video Logo
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
