Question about Maytag Washing Machines
My Maytag MDE6700AYW has been a champ for 10 years. It is now stopping and I am unable to restart it for about 15 minutes.
It runs for about 4 minutes. Is it the motor or is it the Front Panel with the computer? Thank You kindly!
SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Posted on Jan 26, 2009
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 246 Answers
SOURCE: old lawn mower will run for 15-20 seconds, then
Hello:
It Sounds like the Carburetor may Require Cleaning or the Carburetor Solenoid Requires Replacing.
The Following is a Basic Instruction File I made for Cleaning the Fuel Systems on Small Engines. The Following Diagnostics Sound like a Lot of Time. The Time is Really in the Soaking Process. Cleaning the Tank is a 15 to 30 Minute Repair. Check the Gas Tank Cap and Make Sure it is Venting the Tank Properly. Is the Gas Tank Clean? Any Water, Dust Particles, Dirt or Rust Particles will Slowly Restrict the Gas Flow to the Carburetor During Operation. When the Engine Stalls/Quits, a Small amount of Gas Back Flows to the Tank and Flushes this Debris Back into the Tank. The Action of Starting the Engine Shakes the Tank and Mixes these Particles Back into the Gas and the Unit will Run for Anywhere from 45 Minutes to 2 Hours and then Stall. Also, if the Carburetors Internal Passages are Slightly Restricted, and a Slightly Extra Load is Added to the Normal Load of the Generator, the Restriction Causes the Engine to Stall Due to Lack of Proper Fuel to Compensate for the Extra Load. If you Use this Regularly, then I Suggest you Do a Complete Fuel System Clean. Remove the Tank, Tank Outlet Port Valve, Fuel Lines and Carburetor. Then Soak the Carburetor and Tank Outlet Port Valve Overnight in Cleaning Solution. While the Carburetor is Soaking, Clean the Tank. Leave a Small Amount of Gas in the Tank and then Use a Lint Free Rag and Put it in the Tank. Use a Long Screw Driver and Move the Rag Around Inside the Tank and Move any Particles Towards the Fill Hole. You can Use a Shop Vac to Vacuum the Particles Out of the Tank. Use Compressed Air and Blow the Tank Out as Best as Possible. Leave the Tank Open to Air Until the Carburetor is Assembled and Ready for Installation on the Engine. Check the Fuel Lines and make Sure they are Not Rotten and Breaking Apart on the Inside. Replace them if Required. Replace the Fuel Filter if Required. Using a Breakdown of the Carburetor at the Site I Provided, Most People can Disassemble and Assemble the Carburetor (and other Engine Components) with Little to No Problems. The Cost of the Cleaning Solution I Use is $30.00us @ Gallon (I Use Gunk). The Gallon Can Comes with a Tray for Small Parts and the Carburetor Fits Nicely. Most Times a Carburetor can be Soaked and Cleaned and with the Float, Needle Valve and Other Carburetor Components being Soaked in the Cleaner with the Carburetor Body; there are No Parts to Replace on this Carburetor. If you Soak and Clean this Carburetor and the Float Needle Valve Still Does Not Stop the Gas Flow Properly, then Purchase a Needle and Seat Kit and Replace it. The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time. Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish. I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then **Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk). I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning. You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also. The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool. Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed. If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable). The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle. Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts. Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.*** (Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***. ****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body. If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body. Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws: ****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.**** If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle. For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine. Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test. If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle. By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting. This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components. If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear. http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm 2- http://www.cpdonline.com/692509.pdf .
>>Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on Sep 13, 2009
  • 3 Answers
SOURCE: 2002 GMC YUKON XL 1500 MOTOR DIES AFTER GOING
Check the fuel cap!! If the vacuum relief is not working it can impede the fuel flow and cause the engine to shut down or not restart after a stop. Waiting usually gives things a chance to stabalize and the engine will restsrt. When this happens again try loosening the cap and see if the engine will restart.....If it restarts immediately, REPLACE the fuel cap..Do Not leave it loose because this will cause other problems. If it is not the fuel cap the problem may be the filter, the fuel pump, or aome other fuel system malfunction.
Posted on Jan 24, 2010
Testimonial: "Great will try it "
RE LK 3504 (35 hp 4 wheel drive Tractor starts, runs 5=10 minutes under load, then slowly fades away running slower and slower until it stops. Restarts in 15 min, same result
Here is an idea.
It sort of sounds like there is a blockage after a while in the gas tank.
If there were sediment in the bottom of the gas tank, it would start and run fine sitting still.
However, when driving it, it would be a matter of a few minutes until the sloshing of the fuel would cause the sediment to mix in with the fuel, and clog the filter screen in the fuel tank.
When it stops, the sediment would settle back down, and in 15 - 20 minutes, it would be clear again.
God bless your efforts.
May 08, 2017 | Cars & Trucks
Front console removal help for Maytag MDE6700AYW dryer.
Go to www.repairclinic.com and enter MDE6700AYW. You will be presented with a list of common repair parts and may be able to view a generic Maytag video showing disassembly.
Dec 25, 2016 | Maytag Dryers
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Washer started and then stops mid cycle
Try unplugging it for a minute and plug back in, that should reset it.
Jan 09, 2018 | Maytag Neptune Washer
Maytag Neptune dryer, model mde6700ayw, cycle selector knob will not change cycles. It gets stuck on a random cycle even when I power off, power on. Tried to put in service mode but as the cycle selector...
you have a problem with this dryer,the computer board and other parts are no longer available,your better off replacing the dryer.if you go here you can see the parts
http://www.searspartsdirect.com/model-number/MDE6700AYW/3048/0151200.html?searchType=modelSearch&q=mde6700ayw&searchTerm=mde6700ayw
Sep 06, 2017 | Maytag Dryers
Maytag neptune dryer doesnt heat
On the housing the element mounts in is a couple of safetys The smaller one is rated for 300f and the bigger one is rated for 250f. If the smaller one is tripped obviously you replace them both, making sure the vent to outside is clear. Them fuses blow or trip because of air restrictions.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Dryers
The igniter fires the gas, it burns for a minute or less, then stops and won't restart unless the dryer is stopped and restarted? Is this a coil problem?
Sounds like a clogged vent. If you let it run for a few minutes after it shuts off, it will come back on. Your overtemp. thermostat doesn't allow it to work, because the hot air is not being sucked in. But to answer your question, not the coils for sure in my opinion. When coils fail, it won't turn on after 10 min of running or more. Not right away.
Maytag Neptune dryer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Maytag MDG9206 Dryer
Nov 11, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
