Question about Car Audio & Video
Hi I am missing the magazine/holder for my eurovox 1bit d/a converter system mobile disk changer, 10 disk magazine, from my Holden VT I have just purchased (second hand)am I able to get one please?
SOURCE: Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Posted on Aug 12, 2007
  • 3 Answers
SOURCE: Reset button on Sony 10 Disc CD changer
there is a reset button the the converter box that all the wires go into.
Posted on Aug 25, 2009
harpero
SOURCE: 12 Disc CD Changer in 2002 Corvette Convertible
I had this problem on my 2001 Corvette. I took the whole thing out, took off the cover and was able to get the jammed cartridge out by carefully pulling the stuck tray out of the carriage and then removing the entire carriage. Check to make sure your individual trays are not warped. Mine continued to work without problems for about three months and then it happend again. Another thing you can do is not to load a disk in the last (#12) slot. I think it's the one that gets stuck.
Posted on Nov 11, 2009
SOURCE: Installation of vt holden commodore aerial rope and mast
You access the ariel via the left hand wheel arch.
1. Remove left wheel mud guard. It is held in with a bunch of press studs which can be difficult to remove. I found pulling on the plastic mud guard whilst turning the screw helped.
2. unbolt the electric ariel assembly. There is an earth strap that needs to be unscrewed as well.
You should be able to get the ariel out far enough to work on it.
3. Remove chrome plated nut to top end of mast tube.
4. With great anger and force, remove the dead ariel and drive cable from the mast.
It's difficult to get the mast to work unless it's earthed properly.
5. Get you hand inside the wall and remove the ariel face plate. Swear if you have to.
6. Put the ariel mast assembly back into the wall and hook it all up minus the new ariel.
7. Switch your radio on, then put the new ariel into the mast. Gears facing the rear of the car. Switch the radio off, it should retract. If not you may need to push it in a little further.
8. Remove the ariel mast again and slip the chrome nut to top end of mast tube and tighten securely.
9. Ask the spouse to close up whilst you have a beer.
Posted on Jan 31, 2010
dj_relly999
  • 4070 Answers
SOURCE: cd changer magazine does not eject
good day, you may want to do it manually if its jammed, you may find a pinhole on it and u can use a paperclip, insert it in the hole and it will open. hopefully it wont jam again. hope this helps, have a nice day
Posted on Feb 10, 2010
My battery went flat and I jump started my car (Holden VT) now my stereo is locked. Dose anybody know how to unlock it. It's a eurovox radio unit.
Samantha, You need the VIN and the radio serial number. Take those into a Holden dealer to get the radio code and programming instructions from the dealer. They may want a small fee for the #. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forums.justcommodores.com.au/vt-vx-holden-commodore-1997-2002/131983-vt-stock-radio-cassette-player-security-code.html
Radio Security code Street Commodores Online Forum
Go Technologies Eurovox FAQs
Aug 26, 2016 | Holden Cars & Trucks
Kdc-c517fm. shows 99E and will not release disc holder
From the Kenwood manual:
Something is wrong with the disc magazine. Or the unit is malfunctioning for some reason. 99 E: Check the disc magazine. And then, press the reset button on the unit. If the "99E" code does not disappear, consult your nearest service center.
I hope the rest works for you.
Feb 28, 2011 | Kenwood KDC-C517FM 10-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Code needed to activate head unit for eurovox 10 cd stacker
The pin number is usually in the vehicle manual. Visit the wreckers to see if the standard manual was in the car and just check that. other than that you might need to contact holden with the vin number of the car etc to get the unlock code. that is the vin number of the car it came out of. If you cant get that i am sure that they wont unlock it for you as it will be presumed stolen. If you cant get the code from holden, take the stereo back as its going to be an expensive paperweight
Feb 28, 2009 | Audiovox SP11CDP 10-Disc CD Changer
Replacement disc magazine
manufacture of make of cd changer but it would be cheaper to buy new cd changer i would think but worth you checking
Jan 04, 2008 | Audiovox SP11CDP 10-Disc CD Changer
Need Magazine
Jensen RCH or JCH 10RF and CH1002 disc magazines are the same
Jan 02, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
